Darin's P-Limited OPC Lynx build
always jealous of darins builds..see my fleet: http://forums.offshoreelectrics.com/...hp?albumid=294
So nice to see when a plan (build) comes together. But even nicer is to hear of some good racing action to counterract the mumbo-jumbo of the keyboard insurgencies . Congrat's to You & Brian & the others who raced. Thanks for putting it into some welcome reporting.
Toby's got it RIGHT
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
Looks like Jerry Dunlap did it again! Got some fun shots from the races... Was going to wait to paint the hull until after I got the boat sorted a bit and decided if it was going to work or not...
I'm planning the paint now!Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
For a few weeks now, I've been trying to make my own mold so I could lay-up a Carbon fiber battery/ESC cover for this Lynx that would be something more than just the flat cover that I have on it now. Just wanted more room above the battery/ESC so I can have more combination options in the future, and also to make it easier to tape down.
After TWO previous attempts, and with a LOT of help and advice and shopping lists from Brian, I finally pulled a mold that will work!
Has one small spot in a non-critical area (area will be trimmed out after the part is made, you can see it at the top-left portion of the mold) that chipped and left a piece behind on the plug, but otherwise, I think I have a clean mold to work from.
I'm going to attempt to pull a part from it tomorrow and see how it turns out.Darin E. Jordan - Renton, WA
Thought I'd share a pic of the finished battery/ESC cover. Turned out pretty good for my first molding experience. The finish isn't perfect, but I'm told when you vacuum bag, that can often be the case.
I ran the boat this weekend and the extra room over the battery REALLY helped a lot. Makes taping very easy and I couldn't be happier with the way it turned out.
I may re-do the battery access area to give me a little more room to get the cells in and out, but otherwise, this boat is ready for paint. Ran great this weekend!!Darin E. Jordan - Renton, WA
Came out realy nice. Good idea on the connectors; I've thought of doing that myself to solve sealing issues-motor/speedy replacement. Does the extra set of connectors generate any additional heat ? - just curious.
I did that same thing with the connection from motor to esc a while back when I did an aeromarine predator. It worked out good for me. No excessive heat in my caseComment
Excessive heat?? Well... I don't know... The motor has yet to come back over 100-degrees, so I'm not sure I'm actually pushing it yet... Average amp-draw thus far is 86-amps... and it seems to be VERY fast just like it is. Wires are all very short, so I really don't think I'm losing anything through those connectors. It sure makes life much easier!Darin E. Jordan - Renton, WA
Thanks, Tony...
Excessive heat?? Well... I don't know... The motor has yet to come back over 100-degrees, so I'm not sure I'm actually pushing it yet... Average amp-draw thus far is 86-amps... and it seems to be VERY fast just like it is. Wires are all very short, so I really don't think I'm losing anything through those connectors. It sure makes life much easier!2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Tony, I also used REALLY big wire for the pass-throughs... I think it's 8-awg... scraps from a Castle ICE 200... :D I'm still using 5.5 contacts on my motor wires... haven't really seen a need to change them to 6.5's yet, but perhaps in the future... That's a LOT of soldering and swap-out to have to do!) Right now I'm thinking TS-3 for the simplicity and price - I like the ML295 but me & wood boats (and the buoey in turn one at Legg) don't get along.
The Lynx is a 30" boat... :D
As we've both seen, it's hard to beat a well-setup TS-3, especially for the price.
I'd still love to see what I could do with a Stiletto if I could get one made that was about 2lbs lighter. I think it's a good design, that would work well if it were just a little lighter.Darin E. Jordan - Renton, WA
