Hi guys... it's been awhile since I've done a build thread...
Here is my latest project. I decided to give a Lynx a try for P-Limited OPC. No one around here has done one yet, so we'll see how it works out.
I purchased the hull from Ron Drake, and he pre-cut out the radio box to allow for fitment of the FE battery tray. I've cut it out further, and am in the process of fitting a new box now.
Room on this boat is TIGHT, so I'm still playing with the layout. It's looking like I'll be putting the servo towards the front, and I'm going to be running pull-pull cables for the steering, using the steering wheel from a Stiletto on a Spektrum S6030 Digital Servo, mounted in a carbon-fiber servo plate that I'm fabbing. I'm likely going to be running the cables on the OUTSIDE of the radio box, similar to what I did on my WoodStuff tunnel a few years ago. Works well and keeps them out of the way of the rest of the electronics, and also allows for a wider range of motor positions.
Batteries will be placed at the extreme rear of the box, with the ESC either on top, or just in front. Likely will be on top.
The front half of the battery box will have a flat cover, but I'm looking at building-up the back half to allow more clearance above the battery for cables, wires, etc. There is room under the cowl to go up quite a ways in this area.
I'm thinking about using this radio box, once I get it sorted, as a plug and making a mold of it, so I can lay these up out of vacuum-bagged carbon fiber. Might be a worth project to test my skills at that, and would reduce the weight a bit.
Lawless 3.5 lower unit has already been fitted, per the Lynx instructions.
More to come as I progress.
Feels GOOD to be building something once again!
