Ah I see I forget the bad down under boys are used to cooking cupcakes and brownies
Aeromarine Sprint Cat .80/.90 twin 1717's
Last edited by Chrisg81983; 04-29-2013, 06:20 AM.my youtube videos http://www.youtube.com/user/chris81983?feature=mhee -
Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Hey Danny
I read somewhere previously.. you have 2 pickups and four outlets....
Split water will take path of least resistance.. when you rebuild this.. 2 pickups 2 outlets... run water to esc then motors then out.
The fusion here looks like packs dropped voltage under load, esc increased amp draw to feed what your finger demanded.. and low speed low cooling high draw quite simply overloaded the system and flamo..
I suggest 5017/3 is a too large jump up from x447s in a new still trialing system.
Always avail for a chinwag, mate.
I wont say my favorite motto here, although it is most applicable.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
Its actually best to cool motors first a motor will start to demagnetize themselves at the temp a esc can run at if need be but you will have people tell u differently. This is something I tested myself and researchedmy youtube videos http://www.youtube.com/user/chris81983?feature=mheeComment
....cheap motors will demagnetize if not cooled adequately.
However, the 1717's in Danny's boat were built for high yield with passive air cooling . any encapsulated water passage across this motor will extract more heat than design due the higher surface area of the finned can.... more heat extracted than if still air cooled.....
Highest possible cooling efficiency pathways and flow rates are well discussed on this forum and others, documented by well learned and experienced people.
If you also need help with esc, just ask... I aided design a few the recent ones, and repair under factory license many the Eu types .. money for jam, mate .... ( means 'easy work' )
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I have 4 cc 1717 same as danny in same hull as him well had the same hull but still have the motors. That setup will hit 80 miles per hour no problem. I also found cooling the motors first saved me 10-15 degrees on them but yeilded the same on esc's no matter what way I cooled them first or second. I also spun 55mm props with ease. Motors never went over 110 degrees fmy youtube videos http://www.youtube.com/user/chris81983?feature=mheeComment
The motors, batteries and right side speedo where cool, just the one speedo took to amp hit. The hull only needs a clean up as no damage has been done, no re-build needed here, just a clean up and a new esc.Comment
The hull has 4x water pick ups with a cooling line going to each motor and to each esc, that shouldn't be a problem.Comment
I disagree with the the theory that split lines dont work. I have used that set up on several boats without issue. The pressure feeding the lines is more than enough to fill all the lines.The short ones my fill first but water will always flow through both lines. Much harder to keep water out than to get it in.Comment
It's been a while and the cats still sitting up on the shelf (all cleaned up). I Killed my speedo in my losi 5ive on the weekend and have ordered a gas engine to put back in it so I should have a spare castle 2028. I'd love to know if it'll be worth me doing a little work on this hull to drop the 2028 in it and run a 300amp speedo (I have one to use). I think a single cat would better suit my "basher" style of boat driving as it's 1/2 the work, lol. 8s, 10s or 12s, would it be worth the while do you think???Comment
I finally got around to ordering a motor mount for the 2028 along with a 1/4" driveline and a inline strut/rudder to get this boat back on the water. I'll marry the motor up with a sf300 and run 8s-10s with a x457 and see what happens. I'll start a rebuild thread when the goodies come in.Comment
Tag me into the new thread mate.
DocWWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
