Yeah baby! The Sprintcat is a sweeeet kitty! Turns on a dime !!!
Sprint Cat40 twin
I applaud your innovations to the stinger roller bearings, I too, am working on something similar. However, I fail to understand the use of a reservoir, for without some sort of back pressure I doubt it could possibly, auto/gravitationally feed, regardless of oil viscosity.Comment
60cc canister drained after 45 minutes of onwater time.. outlets closed with IV bag clipsl when boat returned for battery change.
I use light machine oil 15-20W.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Originally posted by RumdogYou are going to LOVE this boat. I'd mount the stingers a tad higher than your mock up position though.
Originally posted by RumdogAlso, I am anxious to see how it handles with the long rudder bracket. I used a very short bracket and it worked great.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
Well now, don't I look/feel silly, but you know what they say about dumb questions. Good info, and thankz for the additional picz, Fluid. It's back to the drawing board for me. Doc, do you have bearings on either side of the oil feeds, or just a single bearing? Does the oil drain toward the prop, and/or the transom? Does the cable get any oil/lube? 80cc's an hour, on this side of the pond the EPA would throw my azz in jail, and charge me to drain the lake. Would a higher oil weight drain less, and still provide lubrication? "water lines from rear", rear where? hull, transom, or rudder? Are you satisfied with flow, and temps? Can you see the water exit from your near vertical outlets as you do a low level flyby? (if so, cool). It's a visual I'm also trying to attain, but a flat deck doesn't make it easy.
Sorry to be such a pest Doc, but this old dog is in need of a new trick. Cheerz!Comment
60cc ... yes, flow too fast
15-20W was convenient at time...
feed enters 0.25 ahead the 2 bearings and flows through..natural reservoir between the 2 still holding oil when disassembled later same day.
Hughey 3/16 flex have stub shaft of 2.75" .. .. I have 1.25" between bearing centers.. 1.5" of stub inside stinger ..1.25 out rear ..
I run teflon lined tube in hull to motor.. I use a thin graphite based motorcycle chainspray lube on the shaft flex.
Temps? .. but sure was slippery ...
why?
3/16 roller bearing spec sheets said grease <10k .. oil <35k rpm .. this setup runs ~40k ..
previous hydro roller setup with grease.. when pensioned off.. had grease/carbon nodules 'welded' to rollers + cage.. not very smooth ..
Considered oiler at top the flex .. to feed through .. flow needed at stinger concerned me about 'blow back'.. so opted for local feed.
Will work until someone points out why not !
cheers
W
ergo .. this oils bearings, not flex as is the usual ( as in Jay's pic above )Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
Thanks Fluid for the pics! I was looking for ideas for my MM...24 R/C vehicles and still counting...What budget?Comment
