Was the motor hot? -if not you most likely have too big prop. Is the prop sharp and balanced? -try x442 or similar next.
Looked your pics above and the drive dog/stinger gap looks too big to me,
I keep about 1-2mm gap and that has worked well for my boats.(the gap you have in the pic is not that bad that it would be the only thing wrong)
Cable greased well? -too much friction?
Check that everything moves freely and no binding .
Also blow air in the outlets and check that air comes off the inlets. -you use 1 inlet for esc and another for motor if I got this right? if not make the water flow first in the esc and then the motor.
If these are ok, then could the boat run too wet? -does it barely touch the water or does it run most of the V in water?
Video could help here?
Do you use seperate bec? -TIMING? -I had 7xl that made the esc hot until I got the timing high. -what is the recomenned timing on 1717?
Also , are the trim tabs a bit over the bottom or same line with it/below the hull? -tabs need to be mounted a bit above the bottom.
Pate
Pate
