New Scratch Built Cat
  • mbartley27
    • Jun 2010
    • 39
    Originally posted by Rumdog
    5.5mm bullets are plenty for this setup.
    Why 2 rudders? Just personal preference?
    Yea, the 2 rudders are just because it's a setup I always wanted to do.
    • mbartley27
      • Jun 2010
      • 39
      Originally posted by kookie_guy
      As far as I know, there's no 6.5mm, just 6mm.
      5.5 will be fine. Personally, I use 6mm on everything, and have lots of them, so I'd do 6mm, just to avoid buying new ones.
      Oh ok, My mistake on the size. 5.5mm it is then.
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7116
        whoa!!! very nice... what size - did I miss in OP? looked but didn't see what dimensions you doin. do you have plans or is this your own design?
        "Look good doin' it"
        See the fleet
        • mbartley27
          • Jun 2010
          • 39
          Thank you, thank you.... It's my 1st scratch build. The bot is 38 inches long and about 12-1/2" at the widest point. I found the plans online, but the plans were originally for a 30" boat.. I just had them blown up to this size.
          • mbartley27
            • Jun 2010
            • 39
            Hey guys, I'm lost here. .I got my 9/32" Brass tubes along with the .187 teflon liner. Now, is the brass tube supposed to fit inside the strut? if it just up against the strut, what keeps it there besides maybe some heat shrink tubing and glue? I have the pics to show what I mean.IMAG0743.jpg. I also ordered the prop hardware, left hand and right hand lay cables with prop shaft from Jeff Wohlt. He says the Flex Cables come with the standard 3/16"x 2.25" Shaft. Now my struts are just 2" long. are those cables gonna work? I just feel like I bought the wrong stuff.. I'm just lost!!!!!! Please help!
            • Jeff Wohlt
              • Jan 2008
              • 2716
              You should be fine
              www.rcraceboat.com
              [email protected]
              • Chris Harris
                • Oct 2007
                • 182
                No mistake, they are out there. Castle Creations sells 6.5mm bullet connectors.
                I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
                • mbartley27
                  • Jun 2010
                  • 39
                  #23
                  Well I haven't been here in a while, but here's the progress so far. IMAG0780.jpgIMAG0782.jpgIMAG0790.jpgIMAG0783.jpg
