Dumas hotshot .45 build in progress
  • rcboatmanwithkids2880
    • Aug 2008
    • 340
    Hi JC ,
    Thanks for kind words mate , i feel iv'e just been lucky with project " JPS " in the way that is turning out , though i am only half way through the build . i wanted to build an element of history , fun & something that was a new way of looking at our hobby as I feel there is a level of " follow the leader " at the moment with R/C boat trends , there is so much design in the way of paint schemes in the world that should be rediscovered in our shared exciting form of R/C Boating .....
    Your tunnel that you are building should be lot of fun , if you require some decals made up to complete the scheme your considering , just follow the link i posted earlier in this thread & you will find Lisa is great to work with , as i emailed her around 20 times during the process of making " JPS " come to life visually .....
    P.S - I will be posting more pictures soon , with the pinstriping iv'e completed ......
    All the best in F/E R/C Boating ,
    Brad
    Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
    • lohring
      • Jun 2011
      • 183
      See http://www.intlwaters.com/index.php?showtopic=46440 for the power plant I used on a similar 6S tunnel. Run a smaller prop than the 1450 I ran for an easier to handle boat.
      Lohring Miller
        • Aug 2008
        • 340
        Thanks for the information regarding power plant , i will be setting up as a 6S sport runnner initially to gain some experience with running an outboard . where Andym & i run is a lake that is surrounded by a cement kerb , so i will wait until i take this project Sydneys MBCOFNSW before i eventually launch .
        All the best in F/E R/C Boating Lohring ,
        Brad
          • Aug 2008
          • 340
          Pinstriped
          Hi Guy's ,
          Took some pictures of pin striping this afternoon , still got to complete paintwork in other ways , such as paint orange triangle where i will place safety loop as required in Australia for racing .....
          Brad
            • Aug 2008
            • 340
            Safety loop fitted
            Hi Guy's ,
            Fitted the Safety Loop that is required in Australia for racing F/E , with this build i am using 6mm bullet connectors & 10 AWG Wiring .
            Brad
              • Aug 2008
              • 340
              Hi Guy's N Gal's ,
              I have made some more progress over the last few weeks including bulding an O/B Pod on the back of hull , where i have attached the " Speed - Drive " Lower Leg . The Speed - Drive is made in Bang Kok Thailand , where it is raced with similar hulls such as this , though power set - up is a bit more powerful as they race similar hulls with 7S Lipo's & BL Motor can size of over 60mm according to Narade who manufactures these units & races his product . With this build i was aiming to bring back a level of fun , history & a boat that is not following market trends & i feel i am achieving this so far . It's good to bring history to life & this build being 6S powered it should do that dramatically ......
              Hope you enjoy the pictures that i have taken , they show where i am up to in the build process . As i am not planning on launching until mid 2012 , i have had a few set - ups in mind , which included running 4S for a time . Though i will stay the course , & build it as a 6S Raceboat as i feel the weight of it would be more suited to 6S set up .....
              Currently i have a Keda 40-74-1340 attached to boat & plan on buying a T180 ESC & jury is still out on Props , which i may go for the X642-8 range - so your thoughts would be appreciated in that regard ...
              Brad
              Oz
                • Aug 2008
                • 340
                Latest Progress
                Hi Guy"s ,
                Been busy with Xmas , so good to have a young family at this Time of year which includes two boys aged 7 & 3 & my dear daughter aged 2 , to share this magical time , with my Beautiful Wife Natasha to whom I am forever greatful , for giving me the awesome gift of parenthood which is demanding though rewarding , i am eternally indebted - LOVYA HONEY- BUNNEY !!! .
                Have made progress on Project JPS , which includes seperate intakes for cooling BL Motor & ESC ( see pics ) , just waiting on yellow cooling line to really make the hosing look complete . It is one of the first lessons you learn in Electrics , is that Water & Electronics don"t mix , therefore I have built a cooling outlet on the left hand side & cut off feature on the right hand side , with that in mind I would rather look at water coming from outlet while the boat is racing , to ensure ESC is being cooled effectively . Also have given the hull three layers of clear coat which has given the matt black a deep lustre !!!
                Been concerned as to what Prop would be most suited for this project , thanks to Make a Wake & other knowledgable members ( Thanks Guys ) , I now know what type & size prop range is required ...
                Hope you all had a great festive season , no matter where in the World you celebrated & all the best for 2012 .....
                Brad
                Oz
                • Drax21
                  • Jul 2011
                  • 1021
                  #23
                  Looks great, good job! I too have to make a safety loop if I want to run this year. Never done one before. Can you post some pics of the loop so I have a basic idea. M445 - X642 starting prop. Go up from there
                  Everything that has a beginning, has an End
                    • Aug 2008
                    • 340
                    #24
                    Hi Drax ,
                    If you check previous post that I have made on this thread , you can gain a visual of the top side . also , check out threads on OSE.COM regarding safety loops .
                    In short , it's much like fitting an ESC into your electrical set up . Once you have soldered cut - off plug , drill hole into surface you want device to attached to & use F/G Resin to permanently hold in place. ( No Biggy ) , PM me if you need further assistance. ...
                    All the best in our Great hobby mate ,
                    Brad
                    Oz
                    It may also pay you to check out what Brittish Model Association requirements are ....
                    • Drax21
                      • Jul 2011
                      • 1021
                      #25
                      Originally posted by rcboatmanwithkids2880
                      Hi Drax ,
                      Brad
                      Oz
                      Thanks. If any of you lot think you got it bad with rules, you should check out the SWAMBC rules in the UK.
                      • Steven Vaccaro
                        • 8723
                        #26
                        Sorry about the Spam USER! He has been deleted.
                          • Aug 2008
                          • 340
                          #27
                          Hi Guy's ,
                          Fired up my project boat yesterday using a 4S battery , as I require new batts of 6S Voltage . Can report the Keda 40/74/1340kv that I bought off OSE.COM has no fault thus far . It's good to finally get the motor spinning using " Lipo - Power " , after 8 months of slow build time !!!!! .....
                          Brad
                          Oz
                          • Drax21
                            • Jul 2011
                            • 1021
                            #28
                            Good job
                            • Drax21
                              • Jul 2011
                              • 1021
                              #29
                              Hi Guy's ,
                              Fired up my project boat yesterday using a 4S battery , as I require new batts of 6S Voltage . Can report the Keda 40/74/1340kv that I bought off OSE.COM has no fault thus far . It's good to finally get the motor spinning using Lipos power , after 8 months of slow build time !!!!! .....
                              Brad
                              Oz
                              Need a vid Brad!!
                                • Aug 2008
                                • 340
                                #30
                                Hi Drax ,
                                I need a video too mate ( lol ) , actually Johnny Walker Red would be better ( lol ) . As you know I am sending my boat to Oulton Broad in England to be apart of an exhibition on Bob Spalding's racing career . During the time it's there it is also to operated on the water of Oulton Broad so I am sure video & pictures will be taken for me at that time around May ( your Spring time ) . It's a shame you are not living in the East Anglia region Drax , as Roy Cooper is seeking a competent driver for its time on water. ....
                                Brad
                                Oz
