Finally got servo (lightweight Futaba s3004), 21 rudder, 40 strut, stuffing tube (with .187 teflon liner) installed. I went ahead and installed my rudder on the right side. Linkage is short 440 so deflection will not be a problem. Water pickup will be opened for better pickup. Rudder will also be shortened a little.
Whiplash Sport 20 Build
I cut 1" off of the Speedmaster 21 rudder. I also sharpened 21 rudder on one side and opened water pickup slightly.
Speedmaster mini rudder on left Speedmaster 21 on right.Attached FilesLast edited by detox; 06-11-2012, 08:05 PM.Comment
Almost complete. Footprint is same size as Whiplash 40, but a little lighter in weight (10 lbs).
I will try a few motor combinations just to say "been there done that".
Q Sport Hydro 6s: 1527 1y (1250kv), 1521 1y (1577kv)
P Sport Hydro 4s: 1521 1.5d (1860kv), 1518 1.5d (2300kv), 1527 .5y (2500kv)
My next build will be the Whiplash 40Comment
My Futaba receiver has antenna wire, so i installed antenna. Mount is made from 5/32" brass tubing epoxied to inside of hull (epoxy thickened with micro balloons) . Small diameter silicone fuel line will seal and hold plastic antenna tube in place. Ain't it wonderful what you can learn just by glancing at someone elses build.Last edited by detox; 06-24-2012, 08:38 PM.Comment
