Building the 34" INSANE Mono
  • properchopper
    • 6968
    In order to get this race-ready, I went with a trusty, proven Neu 1521 1.5D, and a T-180 with extra Etti caps and a modified full-chamber cooling cap sparks it up. Speedmaster 60/90 rudder, stinger shortened to place the drive dog near the front of the rudder blade, large split trim tabs and XXL large fins on the business end. Since I'm a glutton for punishment, 4" rails with a Peter Z mount.
  • properchopper
    • 6968
    I intended to mount the servo from the inside of the rails, but it protruded too far inside and would interfere with the speed control. Quick thinking, a piece of aluminum scrap, some cutting, filing and tapping and the servo now mounts from the outside (of the rail) to the inside and I can screw in the servo bolts easily instead of trying to get my fingers inside to hold the nuts.
    Pinned the front of the hatch with a leatherwork rivet. Rear secured with screw-down threaded cap screws. Simple and effective.
    • properchopper
      • 6968
      Fitting the T-180 with the Etti cap board on top of the motor mount under the hatch was close - the bottom of the cap board is insulated from the top of the
      T-180 with a piece of G-10.
      Tricked out some bulkhead fittings for the water outlets.
      Business end : I lucked out and the trim tab adjusters cleared the rudder bracket; only had to trim down one adjusting screw.
      Trimmed down the rudder some; may trim some more after trials.
      • properchopper
        • 6968
        Dove into the sticker box & plastered some on. Simple and understated, but this boat has some great lines in my opinion so not much was needed in the way of graphics.
        The hull is solid as a rock, and with the heavy-duty build I'm really looking forward to it's maiden voyage. Mark already won the FE Open Class at the H2O Gassers race at Legg Lake last week with his, and Greg really likes his (and he KNOWS monos).
        Video to follow, but for now, I NEED SOME REST after cranking this one out in less than a week
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 989
          Very nice build Tony. I agree, sometimes less is more. Why distract from a good looking hull with flashy paint and decals.
          • millzee
            Ozzie Bloke
            • Nov 2010
            • 1092
            Very nice, looks great. Thanks for the informative thread, I'm sure you'll win a few with this one too, good luck and l hope to see some footage.
            "Gimmy Toyz for FUN"
            • yurkanip
              Banned
              • Jul 2008
              • 420
              Tony, looking great. I used your same design on rails, batter/motor mount in my cyberstorm nearly finished...paint soon and it will be put back together.
              Looking forward to seeing vid of it running...
              Patrick
              • Make-a-Wake
                FE Rules!
                • 5557
                Nice build.........!! Are those 65c batts i see thru the plexi?? Whats the mah?
                • properchopper
                  • 6968
                  TP 4S-65C- 5000's -
                  • DPeterson
                    • 842
                    Tony,
                    Man - nice build.
                    Haven't ordered mine yet. Now that I see it again, I'll order mine next week.
                    Oh - better see if you can get some bondo in white.
                    Doug
                    Doug Peterson
                    IMPBA 19993
                    www.badgerboaters.com
                    • properchopper
                      • 6968
                      Originally posted by DPeterson
                      Tony,
                      Man - nice build.
                      Doug
                      Got it handled !
                      BTW, to keep my "Team Bondo" reputation alive and current, during the H20 Gassers FE Open race recently, I hit the "carnage" jackpot when, on the back straightaway at full chat I nailed my dead P-Sport FE 30 that Jeff was driving with my other FE 30 that I was driving. A "2 for 1 Special" for Team Bondo
                        • 9488
                        very nice Tony!
                        So this hull whopped on some Gas boats
                        • RaceMechaniX
                          • Sep 2007
                          • 2821
                          Good looking build Tony, I espesically like the photo booth.
                          TG
                          Tyler Garrard
                          NAMBA 639/IMPBA 20525
                          T-Hydro @ 142.94mph former WR
                          • Punisher 67
                            Ignore list member #67
                            • May 2008
                            • 1480
                            Very nice build Tony , I see the ESC plate has been mounted a little offset just curious if there was a fitting issue
                            Necessity is the mother of invention.............
                            Youtube Video's http://www.youtube.com/user/Titanis2000
                            • detox
                              • Jun 2008
                              • 2318
                              Tony, You failed to mention what prop is that you have mounted?
