32" hotr 90+mph
This topic is closed.
  • rearwheelin
    • 1941
    #46
    Big LOL............
    --Albert Einstein
    • wraith
      • 20
      #47
      nice R1 you got there
      • johnson22456
        Counting down the days...
        • Jul 2008
        • 218
        #48
        1500kv on 9s!!! 49950rpm. Wow.
        Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
        • Doby
          KANADA RULES!
          • 7280
          #49
          Originally posted by JPriami
          You mean you bought something from Chris and actually got it?
          Grand River Marine Modellers
          • Howard Lee
            • Nov 2010
            • 198
            #50
            If the weather is good this weekend i will make some test runs and a video.
            • Make-a-Wake
              FE Rules!
              • 5557
              #51
              Make sure you have continuous vid of the run with the GPS in the boat so we can see this fast boat perform up to your expectations...................
              • ray schrauwen
                • 9471
                #52
                I will show you how i balance my boats. First you need to run the boat and find a good spot to start from. Then make a mark on the boat where you balanced it at. Run the boat and check your speed. Now move the batteries only a 1/4 of a inch at a time. This might take some time to find your best balance. Also your prop angle needs to match your balance. Think of your prop as if its drawing a straight line. If your prop angle is to high, you will have a nice rooster but this will not be the fastest setup. This might help some of the less experienced.
                Nice Yamaha!!!
                Nortavlag Bulc
                • Howard Lee
                  • Nov 2010
                  • 198
                  #53
                  What is the fastest that someone has got this hull up to? 70mph
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3278
                    #54
                    Me,that I know of.75mph and ran out of water. No air dam. It's the silver cat in my avatar.
                    • Howard Lee
                      • Nov 2010
                      • 198
                      #55
                      Do you have a video at that speed? I just want to see how it rides the water.
                      • johnson22456
                        • Jul 2008
                        • 218
                        #56
                        It's on the last page of his build thread, a few post down from yours.
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3278
                          #57
                          Last page of my build thread. It's titled Larrys 32" twin cat. It rides great and doesn't blow over. I don't know center of gravity. It's way forward though.
                            • 9488
                            #58
                            • keithbradley
                              • 3663
                              #59
                              So are you running a pair of 5s lipos in this? I have a pair of 4s stuffed in mine and had to cut the hatch opening to get them in there. Yours must be a little bit friendlier shape for this hull.
                              www.keithbradleyboats.com
                              • LarrysDrifter
                                Big Booty Daddy
                                • May 2010
                                • 3278
                                #60
                                Turnigys 4s 4000mAh fit in the sponsons,Keith.5000's won't though. I assume you have them on the tunnel floor,but lower in the sponsons is better.
