Rumdog's Maritimo build
  • Rumdog
    • 6453
    #61
    bonewar, How is your Timo coming? I gtta see that bad boy run!
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      #62
      Originally posted by Rumdog
      The color is very close to the Miss Geico. No gecko in a kini for me though!
      Nice!
      Don't know how I missed this thread till now.
      • drwayne
        • May 2008
        • 2977
        #63
        Originally posted by bonewar
        triple post ............................what the #$*% just happened then...................................
        Palsy ?
        see attached pic for 'temporary' air dam .... works, so why replace ?
        square edge at front, 3/16x1/4, convex at rear
        W
        • Rumdog
          • 6453
          #64
          Thank you sir! Quite a bit smaller than I imagined. I use one on my sprintcat. It's about 1/2" square. Works well, but bounces a bit at mid throttle. I'm gonna fab something up before I leave work today and attach it with double sided tape.
          • Rumdog
            • 6453
            #65
            Just got done running in a snow storm. Fun times! Frozen fingers! Airdam worked excellently! I had one esc prematurely hit lvc, so I'll have to turn the lvc settings to off. I was messing around doing full throttle launces from a stop. It rips out of the water slightly nose up and looks cool as hell. I'm sure thats what caused the lvc to kick in.
            • drwayne
              • May 2008
              • 2977
              #66
              Glad it helped.
              I use one of the OSE LVC circuits that is independent the 2 esc.. attached at Rx and fed to 2xesc from there... if at wot one cuts out, ouch !
              slows it down without cutoff...
              W
              • millzee
                Ozzie Bloke
                • Nov 2010
                • 1092
                #67
                Rumdog, love the build!!
                "Gimmy Toyz for FUN"
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  #68
                  So... um... I get this really messed up thread subscription email...
                  Then I come here and I see, we all love Rummy's build. =)
                  I guess it's true, things are better with moderation.
                  Rummy, have you thought of adding some caps to help prevent the voltage drop?
                  I've been watching voltage drops with telemetry and trying to figure how to calculate what farad capacity would eliminate the drops or reduce them dramatically. After all, that's what caps are designed to do. Might experiment with a dozen 4700's in a bank to see what happens to the drops.
                  • Rumdog
                    • 6453
                    #69
                    Thanks, Ben. Yeah, I have the caps to add. Prob. will do this weekend. I may need some vinyl from you. A couple sets of the kitty head and the banner graphic. Are you out of stock currently?
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #70
                      On the hulls, yes, they sold out fast this time around... The 42mm mounts are in flight.
                      EDIT: Oh, the decals.. whoops! I forgot to add stock!
                      I have some stock updates to do on the decals. I'll see if I can get some photos of the new materials.
                      • Rumdog
                        • 6453
                        #71
                        Quick vid: http://www.youtube.com/watch?v=cGKR-QNM11A
                        one more: http://www.youtube.com/watch?v=-kEK7exLIM4
                        • chummer
                          • 636
                          #72
                          That is Fast!!
                          I want it!!!
                          Nice job Rumdog.
                          "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                          • Rumdog
                            • 6453
                            #73
                            Thanks! It may be for sale
