Rumdog's Maritimo build
  • Rumdog
    • 6453
    I'm currently starting a H&M Maritimo build. Bought the hull from JMSCARD. The previous owner did some excellent glasswork relocating the faux exhaust ports from the hatch to the rear of the deck also making them functional water exits. Looks very slick. Will not be adding any of the scale type intakes. It looks very clean this way. The previous owner had it set up as a twin which I will be carrying over to it's new incarnation. However, the motors were mounted VERY far forward and it looked like he ran the lipos on the tunnel. Not too big a problem, but just not my style. Today, I cut out some 3mm CF plate for motor mounts. Cut down the stuffing tubes a couple inches, and removed the stuffing tube supports. I lined the hull with some CF cloth. Came out OK. I HATE working with the cloth, but like the look. It really didn't need much reinforcement, if any at all. I over saturated it because I like the wet look. I'm looking to push this hull. Realllllllly push it! I'll keep posting progress.
  • oscarel
    • Dec 2009
    • 2130
    Hey Rum, can you post a pic of the water exits? I was thinking about that for my stryker but instead went with them exiting on the tunnel.
    • Rumdog
      • 6453
      The actual tubes are taped up right now in prep for paint, but you get the idea..
      • oscarel
        • Dec 2009
        • 2130
        That looks cool, are those airplane pushrod exits??? http://www.horizonhobby.com/Products...?ProdID=ERN105
        • Rumdog
          • 6453
          They were actually cut right from the rear of the hatch, then transplanted to the rear deck. Whoever it was who did it did a great job. Better than I could have done.
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Whats the powerplant info?I do have an idea that would rock in that hull.
            • rearwheelin
              • 1941
              ManualW has a pair of LMT that pushed a cat 100mph in the 2009 german SAW a couple pages into tha swap shop !! Looks like they are in good shape...
              --Albert Einstein
              • bonewar
                • Jan 2008
                • 549
                Very nice Rummy,
                Whats the plan mate.
                Spill the beans.
                Bonewar
                SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                • forescott
                  Hopelessly Addicted to RC
                  • 2686
                  Yeah, give it up! Don't be a tease!
                  • Rumdog
                    • 6453
                    Twin Neu/CC 1515 1y's, just like my much bigger Sprintcat has. 5s1p per motor. Detounged C-R x447's.
                    • Rumdog
                      • 6453
                      Update. Motor mounts installed, along with the motors. Stuffing tube support is next. The the Rudder, servo, and linkage.
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        Nice.Slowly but surely.Did you make the motor mounts?I like the relief notches you made for the motors,but where they square off a 90 degree angle,you might be better off using a small drill bit to take the corner out.Just a suggestion.Ive seen stress cracks develop when its just cut and not rounded.Im not criticizing,just throwing something out there that may be helpful to you.She looks good.I like the CF job.
                        • Rumdog
                          • 6453
                          Thanks, Larry. Yes, I did make the mounts. Easier than I thought it would be. The notches arent quite done yet. Theyre rough cut, for now. I really actually cut out a lot more than I needed to.
                          Wont be too long before she's on the water. Then the dreaded tear down for paint...
                          • keithbradley
                            • 3663
                            Lookin pretty hot with the carbon fiber bro. Is that .150" or .187" flexes?
                            I wouldnt mind seeing some of your stuff run this summer. We should plan some time to get the Michigan guys on here together this year.
                            www.keithbradleyboats.com
                            • Rumdog
                              • 6453
                              Thanks, man! Flexes are .187".
                              For sure Keith. We'll have to meet up this summer. I was thinking about giving racing a shot this year, but I don't see it happening. I really don't run any P limited boats, and that's the hot ticket in the Michigan club.
