Thanks to the generosity of my racing benefactor, Mr. Michaud, I got to build a dedicated P-Sport FE 30 to compliment my FE 30 P-Spec LSH boat.
Borrowing the 1515 1Y & T180 from my Vegas, I decided to go solid & sturdy with the components. The front-mount motor mount Jeff supplies for the FE 30's is super strong so I went with it, although I added a 3/32" ply base for added rigidity. I used a .150 flex with teflon so I can pull the teflon & run a .187 if need be.
Because I wasn't sure of battery/batteries placement, I used 90 degree fittings on the SC to allow room for dual batteries on the side if I need the extra capacity, and 4S 4000 Turnigy Nanos fit beside the SC should I choose to go this route.
[more pictures in following posts]
Nortavlag Bulc
. I tried to tap threads but the tap wouldn't bite into the brass inside the plate. Luckily I had a bonkered T-180 to use as a plate donor. Best to apply some heat around the fittings before attempting to unscrew them !
) A heat sink donated from a junked computer, which is EXACTLY the same dimensions as the top plate. Enclosed & plumbed, should do the trick. Then again, methinks that if one needs that much cooling the setup should be re-thought. Oh well...
Just like how ferarri inserts valve seats by dipping them in liquid nitrogen then pressing them to the block then they expande.......
