My Mean Machine build
  • Rich
    • Jan 2008
    • 551
    #61
    I couldn't believe it either! I just got 2 feet of snow and am tempted to try my meanmachine in it lol
    • dana
      Banned
      • Mar 2010
      • 3573
      #62
      So i ordered a bunch of stuff to start building now that paint is finally done. I got a leopard 4074 2200kv motor and appropriate carbon fiber mount plus nice water jacket, speedmaster 21 rudder with 2.125 setback, seaking 180 esc with program card, .150 cable with3/16 shaft,and some random small items. should'nt be long before they're here, OSE is 20 mins away and kintec shipped today..Saturday kinda cool thanks jan
      • D&D
        • Aug 2009
        • 185
        #63
        You can look at my pictures and see the setup I used for my MM. I sweated over this a great deal as this was my first electric build, used to build nitro boats. What I found was that placement of the motor, escape, etc. (for boat balance) was not as critical as nitro as long as you give yourself a nice area for you batteries as you can move them back and forth. I run a Castle HV180, Neu 1515.1Y, Etti mount on 4S2P best GPS speed has been 58.5mph. Watch it run on YouTube
        • dana
          Banned
          • Mar 2010
          • 3573
          #64
          here are a couple of pics of my progress so far.... all speedmaster hardware, leopard 2200
          • ls1fst98
            • 859
            #65
            glad to see we mounted our servos int he same spot haha! looking good.
            • dasboata
              • Dec 2010
              • 3152
              #66
              http://www.youtube.com/watch?v=_9CXMd_Cd3Y
              so thats 58 MPH in that vid ??
              • D&D
                • Aug 2009
                • 185
                #67
                The video of the D&D Mean Machine was GPSed at 57.5 MPH. I only had one run at 58.5, most all of my other runs varied from 57.2 to 57.5 MPH. Frustrating, considering all of the different variables (props, balance, strut depths, etc.) I tried. But, it was consistant......
                • forescott
                  Hopelessly Addicted to RC
                  • 2686
                  #68
                  Looks like low to mid forties at best in the vid. Wonder what prop was used?
                  • dasboata
                    • Dec 2010
                    • 3152
                    #69
                    Yup that what I was thinking low 40's sorry to hijack your post !!!
                    • forescott
                      • 2686
                      #70
                      Looking good Dana. Is it just the pic or does the rudder look reeeally long??
                      • dana
                        Banned
                        • Mar 2010
                        • 3573
                        #71
                        It's 5 1/2 rudder. I figure I can just shorten it up a bit, no biggie. It's speedmaster 21 rudder
                        • Rich
                          • Jan 2008
                          • 551
                          #72
                          I have the same rudder and I found that it performed better after I took a bit off.
                          • dana
                            Banned
                            • Mar 2010
                            • 3573
                            #73
                            heres a couple of good ones
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              #74
                              so im ready to do some wiring. since im doing parallel wiring im wondering if 12ga wire is ok for my parallel connectors? im thinking 8mm bullet for esc to parallel split, then 5mm to the batteries...
                              • dana
                                Banned
                                • Mar 2010
                                • 3573
                                #75
                                guys, heres where im at. got everything in there. heres where i put my seaking180 esc, because i have a subhatch. wrapped cooling lines with radio wiring, keeps everything in place. cooling lines get holes drilled just big enough so hose slides thru, then aluminum tube just bigger than i.d of tubing pushed into the tube in the hole. the aluminum pushes the silicon open and puts pressure and creates tight seal, and acts as quick connect for colling lines going into the boat, you can see what i mean in the pic, i left one line disconnected. x442 for now.
