My Mean Machine build
  • forescott
    Hopelessly Addicted to RC
    • 2686
    #31
    How come the first 2-pics are different from the 3rd??
    • DISAR
      • Aug 2007
      • 1072
      #32
      I painted the boat and made new hatch, the 3rd photo is how it looks now. The internal arrangement is same. I will post some "fresh" photos from the inside
      http://www.rcfastboats.com/
      • DISAR
        • Aug 2007
        • 1072
        #33
        my mean machine
        • dana
          Banned
          • Mar 2010
          • 3573
          #34
          3rd times a charm right? i'm confident i got it right this time. i switched to 80 grit 3m automotive sandpaper vs. the wood sandpaper i was using before ( which didnt seem to really do the job well ). the new paper did a MUCH better job roughing the surface up. i spent alot of time sanding then cleaned with Acetone. finally i got finishing resin which has a MUCH slower dry time than the 30 min epoxy i was using before. ( 45 - 50 mins work time and 3 hours to tack free!!) which i reduced with 91% alcohol vs. the 50% i used the second time, causing the epoxy to dry rubbery. this time im almost 100% sure i got the bond ive been looking for
          • dana
            Banned
            • Mar 2010
            • 3573
            #35
            can somebody please tell me how much setback is needed on the rudder when using the speedmaster 21 strut with mono bracket? im not sure of the dimensions on the speedmaster strut... the front edge of the rudder should be in line with the front edge of the prop? would this be right? or should it be setback a little behind the prop....
            • Scott T
              • Oct 2007
              • 590
              #36
              I think my rudder's leading edge was in front of the prop on my MM. To answer your other question, the back edge of a Speedmaster 21 mono strut is 2" from the transom. Add 1/4" or so for drive dog, and that's where your prop starts.
              Scott Tapsall
              Pine Rivers Model Powerboat Club - Facebook Page
              My Gallery
              • dana
                Banned
                • Mar 2010
                • 3573
                #37
                ok let me ask you this scott... how well did it turn at slow and high speeds? my sv27r turns fine at high speed but will not turn at all at low speed. im trying to avoid the same problem here... thanks dood!
                • ls1fst98
                  • 859
                  #38
                  i believe aeromarine recommends the longer version of the 21 rudder, i think its 2 1/4 set back. i hope thats the correct one cus its the one i just ordered for mine
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    #39
                    yep that is what i've been planning... seems like the right choice
                    • ls1fst98
                      • 859
                      #40
                      sweet! cant wait to see yours! got a list of parts coming from OSE and some others.
                      • Scott T
                        • Oct 2007
                        • 590
                        #41
                        Mine turned fine at low speeds. I had seen a few MMs built with the mono strut and hydro rudder brackets, so followed suit. At high speeds it would occasionally hook or slide - depending on the water conditions. I'm sure I could have tuned it better, but it was very competitive and I never had much time for testing. I've since sold the boat.
                        Scott Tapsall
                        My Gallery
                        • dana
                          Banned
                          • Mar 2010
                          • 3573
                          #42
                          here is color card sprayout for MM. i like it
                          • Rumdog
                            • 6453
                            #43
                            It should turn well at low speed Dana. Monos are worse for low speed turning. You have to be going fast enough to bank to the side of the hull before it will turn well. Mean machines are some of the best turning cats out there.
                            • DISAR
                              • Aug 2007
                              • 1072
                              #44
                              That's right, the mean machine can turn at higher speeds than most (maybe all) of other boats of same length. I saw that with mine running against other cats of similar size but different makers (H&M etc...)
                              • blizard05
                                • Jun 2007
                                • 576
                                #45
                                My MM is in the paint shop, geting a flame paint job
                                America home of the free, thanks to the brave [/url]
