Maiden run
It warmed up to the low 40's today so to the creek I went to try this boat out on it's maiden voyage. It was both good and bad. It was good that it worked, but it was severly underpowered in the current. It would hold it's own, but just barely. I tried both 2s and 3s lipos and both were about the same. Heres the vid. I also drilled out the cooling tube off the nozzle. This helped alot because it produced a 1 1/2" to 2" stream out the side. Next step to go brushless. Stay tuned.
I just don't think that it will make very much speed because of the small impeller size and if you used in a much larger boat it may take 2-4 of the units to get any speed at all. I still will get some vid of it running on both 2s and 3s lipos.
