Thanks Scott...............nice! I see we have the same stinger and rudder except yours has two pickups. Do you still have it.........any vid.............top speed...........?
39" Mono, Castle 1717 build.
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Nice vid Scott..................i remember seeing that one before with the sound bouncing off the hillsides......sounds mean!
2 questions:
Do you think since mine is a 1580kv and a bit smaller motor that i should use an x445........447...?
Is my ESC adequate based on the smaller props i mentioned? Im not going for huge all out speed or SAW runs, just fun/friendly racing, so i was thinking a bit smaller prop, keep things cool and amp draw down a bit.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
The 1717 has plenty of power to spin a big prop. However @ 35000 unloaded rpms a big prop is not a good idea. I think your in the ballpark starting with the 45mm prop. Thats probably barely enough diameter to get this big heavy hull on plane, but I know guys have used them with luck. Its a good starting point. I'm thinkin' that you'll end up with a cool reliable setup and a prop in the 47-48mm range. Ideally I think that motor will run better on 5s, with the 452. I'm looking forward to seeing it run!Comment
I own several T180's and have been very pleased with them as well. I run one with a Neu 1527 1y in my 45" Dumas and have had zero issues with it. I have heard the same thing about the conservative rating, that they are more like a 200 amper. In fact, I ran across this from G-freak(dont know much about them) "ACTUAL FACTORY SPECS ARE 180A CONTINUOUS AND 360A PEAK BUT WE RATE THEM REALISTICALLY, BASED ON OUR EXTENSIVE TESTING, AT 200A CONT."
Thanks, i'll throw an x445 on first................got a 447 as wellNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I know I didn't think the x445 was enough diameter at first... but I spun her with some real rpms... mine (now brads) has a ball bearing strut too..!Comment
Got some more done, Looks like Darth Vader's rig.............
--------------------------------------------------------------------------------------------------------NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
nice boat!!!Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
Thanks, gotta mount the servo and ESC tonite.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Servo mount.............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
