OSE Brothers Outlaw
Ok I decided to take more out of this hull to clean it up some
the stock 60amp esc that came in this boat, I'm going to use in the 16.5" JAE Rigger
took the tray out.. now I need a sweet looking servo mount
Brushless, Did you think about moving the motor to the back and putting your batteries forward. Could make a sweet layout. Worth a try. The stuffing tube looks like it would be easy enough to remove."IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"Comment
Ok I get ya.
How far back to you think the motor should set, or how close to the transom should I put it?
ideas??
another good one man!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
I honestly don't have a clue without ever touching that hull. I am waiting on a HK Vanquish then I will know better, I think they are very close to the same hull.
Try moving the motor back far enough and keep it low enough that you can still make a smooth gradual bend in the stuffing tube. I would move as far back as you can but make sure to leave plenty of room to loosen the coupler.
Make a nice battery tray between the stringers for 6S 2P. Try to mock it up and see how the COG works out. I would make sure that you can always get 27% to 33% just by sliding the batteries forward. That way you have your ass covered for all different running conditions. Nice and loose or choppy water."IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"Comment
I'll get some things mocked up in a couple hours and get a better idea for the both of us
I do like the battery tray in the hull you are getting.. lots of room for big batteries and slots for velcro straps
I will gut that hull when I get it. I plan on using 4" stringers in it. It will help keep the bottom of the hull from flexing. You should be able to fit a nice plate between your stringers and run 6S 2P. I wish I had some pics of my old DF layout. I am building another one though, I should have it back together in a couple of weeks."IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"Comment
WOW!
it's been over a year
lets get this baby rolling!!
ok a little mock up.. not sure where the sweet spot is, but with 6s2p this is about 26-27%
any and all who want to give ideas, I'm all ears
yes, a few have run the T180 with great results...
but... I want to run 8s on this once and a while, so I'll need a different esc for that
I give this a try in mock up...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
