Jeff are you saying to bring the stuffing tubes down thru the tunnel or out the transom behind the sponsons? My factory strut would be basically butted against the transom unless I made a extended mount for them.
Thundercat31 twin
Got a little work done this weekend. Holes plugged and transom filled and primed and got some under hull water pickups installed. Nothing that exciting yet.FE BOATING: Less like a hobby and more like an addiction!Comment
With that hull you can do stingers and they are cheap. You do not need long ones. There are a bunch at HOR racing or other places. That hull has great room for a twin set up.Comment
I think I will stinger it Jeff. Maybe the ones Kintec Racing. Would the bearing ones yeild higher speeds?FE BOATING: Less like a hobby and more like an addiction!Comment
Slapped some primer down and installed the servo mount tonight. Pretty boring stuff hang in there.....FE BOATING: Less like a hobby and more like an addiction!Comment
It's the one they sell on here. Very good quality and pretty sturdy once tacked down.FE BOATING: Less like a hobby and more like an addiction!Comment
Got my motors in. Going with the Scorpion 3026-1600kv for sure. Waiting on stingers for Kintec and got the bottom painted. Used ace hardware appliance epoxy. Went on great and looks good. Well It would look better if I would have sanded the primer a little better.Attached FilesFE BOATING: Less like a hobby and more like an addiction!Comment
It is a hard finish also. Dries fast and looks good. Yeah its gloss white.FE BOATING: Less like a hobby and more like an addiction!Comment
Got one stinger in. The other one is backordered......FiguresAttached FilesFE BOATING: Less like a hobby and more like an addiction!Comment
Hull and hardware is up for sale in the swap shop!FE BOATING: Less like a hobby and more like an addiction!Comment
