Osprey 41-inch mono
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1679
    #31
    I never have a problem with .250" and .187" cable with water comming in. No hocus pocus, tubing, heat shrink etc. I use this setup on all my boats except my spec rigger. 7/32" will be tight and can be made to work if you have very little to no bend in the stuffing tube. Remember this is the size of the bushing that your .187" stub rides on.
    I really like what your doing to this hull. Everything looks nice and clean! Keep up the nice work.
    • forescott
      Hopelessly Addicted to RC
      • 2686
      #32
      Almost done. Got the stinger bushing in correctly(thanks baked). Routed all the water lines. Prepped the 180 for an rx pack. Servo linkage hooked up.Rx waterproof and secured. All that's left is a couple of holes in the transom I forgot to epoxy and a final tub test, and cooling line test. I should have it on the water this weekend!!
      • Brod
        • May 2009
        • 196
        #33
        Interesting project,i have a similar size hull and waiting to see how yours goes before i decide on power setup for mine..
        Slow gets boring fast.
        • Rich
          • Jan 2008
          • 551
          #34
          I am dieing to see this thing go..looking at the motor trying to decide what i want to put it in :)
          • forescott
            • 2686
            #35
            Rained all day today. Hopefully get some clear weather tomorrow.
              • 9488
              #36
              Looking forward to how well this build runs
              • alerc
                • Jun 2008
                • 3
                #37
                news? video?:)
                • forescott
                  • 2686
                  #38
                  Finally got a chance to run it yesterday. Only got a couple of passes before it began to lose power. Limped it in and removed the hatch. The stuffing tube was pretty hot. Then I touched the collet. It was blazing hot???? I thought the 7/32 stuffing tube was too small and causing the brass to overheat, but why was it cutting out? Come to find out the collet was tight but the flex would still spin inside the collet. So thats where all the heat was coming from and why it seemed like it was cutting out. It was just slipping.
                  Apparently I had the flex cable run all the way inside the collet until it hit the motor shaft and the collet wasn't getting a good bite at the end. So I cut about 3/4 inch off the flex and re installed the cable and tightened the collet.
                  Today I gave it another shot. It ran smooth and fast without any issues this time. GPS was acting up so I had to run it a second time to get a good speed reading. It ran 50.3 mph on the x452. My temp guage battery was low so I kept getting error messages when trying to get a temp reading. But all components were barely warm to the touch. And the stuffing tube that I've been worried about was as cool as a cucumber! The osprey is kinda hard to keep in a straight line at high speeds because the rounded hull bottom with no ride pad makes the boat want to teeter left and right a bit. But its kinda cool having a large hull that can handle a little chop without having to worry about flipping. Next is more prop testing and a video. I'll try to get one up this weekend.
                  • Simon170
                    • Sep 2010
                    • 101
                    #39
                    Sounds like its going well. Looking forward to seeing the vid
                    Still in dry dock... But planning to get wet soon.
                    • forescott
                      • 2686
                      #40
                      Got a carbon 54mm & 57mm from ose for testing today. Once I figure out the right prop, I'll probably have egneg fix me up with a nice S&B brass prop.
                      • Alfa Spirit
                        • 2131
                        #41
                        Nice job, I will buid a 39" Fountain deep vee from MHZ with a Castle 1717.
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          #42
                          Cool. Looking forward to the vids!
                          I'm quite curious about the handling and how you get it sorted, COG, stinger angle, etc.
                          • chummer
                            • 636
                            #43
                            Wow... That's amazing. Great job. I honestly did'nt think it was possible to pull those kinda speeds running 6S on a hull this size. I would have thought bigger voltage. Goes to show what I know.LOL.
                            Man, was gonna do a new gas build this winter but now you got me thinkin'
                            "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                            • chummer
                              • 636
                              #44
                              Is this hull a true 41"
                              • forescott
                                • 2686
                                #45
                                Stinger angle is neutral, and I'll get the cog and post it with a video.
