Delta Force Copy 33'
if you are still looking for 6s motor you can also test this one
http://www.hobbycity.com/hobbycity/s...0_Heli_(1400kv)
with this motor mount
http://www.offshoreelectrics.com/pro...prod=ose-80230
I use this mount with a scorpion 4025 and fits nicely
I used to run the Align in the past on 4-5s for sure the 180A can handle it with 45mm propsTwin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
I used to run the Align in the past on 4-5s for sure the 180A can handle it with 45mm propsComment
The 1400 kv not yet, waiting for it.
The Align I had a similar cooling jacket like yours but at that time there were no cooling mounts. I had some temperature issues in my df 35" ( 170 F) and I changed it.
I bet that the the Turnigy 1400 is by far better and bigger than the Align.
The outrunners also like a cooling fan to keep the temps down.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
I have the back filled with some fiberglass filler.I dont know the exact name if it,but it works awsome and is hard a rock.I think if I hit something the hull would disenegrate and my f.g. filler would still be intact.A little finishing putty fills in some minor imperfections and it ready for the mounting holes for the hardware.I have to read up on the tips and info section for drilling the stuffing tube hole.Im not sure if I want to use a teflon liner or not.Im also worried about water seepage through the stuffing tube.Flex shaft will be .150.Attached FilesComment
Got back to trying to polish my turd of a mono.I finally got a rudder/mount that will physically fit on the transom.Its a SpeedMaster mini mono rudder.It barely fits.I originally wanted a dual pick-up,but this one will do.
I bought some paint stripper and there were 9 LAYERS OF PAINT!!!I almost couldnt believe it.I could feel a weight difference from before and after stripping.Attached FilesComment
Freshly painted interior.Its International Harverster white.Probably going with an IH paint theme.Also made a mount for the Turnigy 180 esc just ahead of the motor.Also used a new aluminum servo mount from OSE and made a mount for it from the same plywood as esc mount.Attached FilesComment
Here it is with esc,Align 600 1650kv outrunner,new stuffing tube,and possible battery placement.I plan to use 6s for this build,so as a precaution to the T-180,Ill be disabling the BEC.I also just bought a Leopard 4082 1500kv that will end up in here.Im sure the outrunner will get hot,but I have to try it.Attached FilesComment
Hey Larry that Align motor will be fine in there on 6s no problem. The speed controller won't smoke either. I would try it on 15deg timing and run with x442 prop for starters. That motor is rated at 70a constant and 85a for a minute so the t180 will be fine. That's a fine looking water jacket btw......FE BOATING: Less like a hobby and more like an addiction!Comment
Ive decided Im not painting this hull.Its my rat boat.Now,I dont have to worry too much about the hull and its something different.I ran it with a Leopard 4082 1500kv on 6s with a X447 and it did plenty of hoppin.I think the prop was too big,but theres always more testing.Now it has the Align outrunner for the next run.And the cooling jacket is sweet.Comment
Where did you get that cool Dangerous When Wet sticker???Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230Comment
Lookin good Larry, now get that puppy in the water!FE BOATING: Less like a hobby and more like an addiction!Comment
This junk boat hops like mad!I propped down,adjusted the stinger,messed with COG..etc.COG was at 9 7/8" and still hopped.Tried 10",still hoppin.Now Im getting frustrated.I cant seem to get this thing to run wet at all.The entire hull is out of the water.I can hold the throttle at half and its fine-above that,its back to the hump.This is my 1st mono,so Im new to this style of hull.Any suggestions?Comment
Throw that thing in the trash...
Just messing with you. At least yours didnt almost sink today.Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230Comment
