May JAE Build
  • longballlumber
    • 3119
    May JAE Build
    I ran it twice on Sunday, but I still have some things to work out...
    Later,
    Mike
  • detox
    • Jun 2008
    • 2310
    Nice!
    I notice you are using the large Octura .187 collet. I have yet to see one of these 5mm collets that are perfectly true with no wobble. I like the smaller 1/8" Octura.
    Is that a Hightech Mighty Mini servo (hs-225mg)? The lighterweight mini servos are underated. I will be using one in my Whiplash
    • Rumdog
      • 6453
      Originally posted by detox
      Nice!
      What do you mean wobble? Unbalanced? Runout? All of mine work fine. Good looking buil Mike. Why the standoff on the transom?
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        Nice! These boats are fun. I just put a new UL-1 motor in mines but it seems slower.
        • longballlumber
          • 3119
          Nice!
          Since I am using a .187 flex cable the large Octura is nearly my only option. I could try a set screw style, but I am not a big fan. It sounds like getting a gorilla to tighten this collet up is the trick. I will make sure it really tight next time I run the boat. That won't be for a while though...
          Sounds like your talking about the runout on the collet. So far mine seems to be fine. I have seen many that were alot worse.
          I am using a Futaba S3016 Mini Metal gear for Steering. This is an excellent servo.
          http://www3.towerhobbies.com/cgi-bin...?&I=LXXWB5&P=7
          Later,
          Mike
          • longballlumber
            • 3119
            Hey Rumdog,
            this is a trick that I learned from another long time nitro boater. I used brass threaded inserts into the block to allow mounting for the hardware. Now the only 2 holes in the transom for water cooling and the rudder linkage.
            Instead of 8 holes in the transom; I have 2. Less chance of water leaking in.
            Later
            Mike
              • 7990
              It sounds like getting a gorilla to tighten this collet up is the trick. I will make sure it really tight next time I run the boat....
              Use a small amount of Never-Seize on the collet threads. This allows for easier make-up and a very tight collet.
              • longballlumber
                • 3119
                Excellent suggestion; thanks Jay...
                Later,
                Mike
                • Eric Bourlet
                  • Jan 2010
                  • 104
                  Later,
                  Mike
                  If you contact Steve at OSE he has some nice small ETTI couplers I use on my .187 cables. I use a UL-1 motor and they work great, much smaller than the octura and run true. If you are using a true P motor they may be too small . and that is why Steve was not listing them on his site but for a Spec motor they are great .He did have them in stock when I got one for a new build (2nd boat) last month.
                  Eric Bourlet
                  Team Airtronics
                  Team M&D Designs
                  • 6S HYDRO
                    • 1320
                    I dont understand, its sitting on the box for the kit but looks to be a scratch build?
