Roll Over Tests
I am very pleased with how this boat rolls over. The best decision I made during the build was to push the motor foward in the boat. The second was to trim the servo mount enough to get a 4s battery room to mount all the way back if needed on the flood chamber side. After several tests, the key to the whole thing is to have the battery on the non-flood chamber side in tight(1/2" - 3/4") to the drive shaft. This is not possible with the way the boat comes pre-built because the motor is mounted closer in and prevents the battery from being pushed closer to the shaft. It also prevents you from mounting a 4s battery against the flood chamber wall. I shifted the flood chamber side battery from the back to the front along the wall and the boat flipped over equally well. Being able to move the battery back and forth along the entire flood chamber wall will help me fine tune the Center of Gravity as needed. Having the motor pushed foward in the hull helps with that as well. If someone were doing this build again I would recommend pushing the motor another 3/4 inch foward to keep the battery away from the collet. I am going to do some work on that issue to ensure the battery stays where it needs to be on that side.
The last picture is the only one that would not roll. The battery opposite the flood chamber is to far away from the center point for the hull. All other configurations flipped withing 8 seconds.
