Suggestions for an EKOS hull
This hull is the same dimension as the EKOS hull (my EKOS is full, so wouldn't help this demonstration)
I couldn't fit them in the sponsons without bending the tinned wire ends on the PC board. The water inlet/outlets are about the same height as the cowl hatch landing shelf.
If you could make them work, it would be a tight fit. Looks possible, but very tight at best.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Fighter,
Thanks for taking the time to post those pics.They do look like they are going to be a problem to fit. This sucks, the price is right on these and they seem to have great reviews. Can the wires be removed and soldered so they are flat???
Does anybody have any good suggestions for an ESC that would be a good alternative to the 180 Turnigy's??
I might re-think the ESC's. I do have one Hydra 240 so maybe another one is in the cards."IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"Comment
Fighter,
I might re-think the ESC's. I do have one Hydra 240 so maybe another one is in the cards.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Twin Hydra 240's would require a LOT of battery. Might be too much for just two lipo packs.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
So, maybe not the perfect set up but here goes. Running twins draws a bit less amps. I run 540 10XLs in the HOTR hull.. same as EKOS. I run 6S and use Turnigy 120s. On a single powered boat, I should be drawing on a 442 about 118- 119 amps. I spike at about 90A per side. That being said, you may be able to sneak by w/ the 120s. Although the 2200s will pull somewhere in the 125 range single drive, on a twin Id estimate about 100A per side. Not saying its a perfect set up, and your not going to be spinning 447s... but it could work. And it will all fit... barely. These hulls fill up really fast. There is no room at all for what we all want to do w/ them. Also, your rgiht on track w/ that set up... Id bet youll be darn close to 60. May not get you the reliablity you want though.. but if you keep an eye on things and dont do anythign drastic, people have pushed these 120s a lot harderComment
So, maybe not the perfect set up but here goes. Running twins draws a bit less amps. I run 540 10XLs in the HOTR hull.. same as EKOS. I run 6S and use Turnigy 120s. On a single powered boat, I should be drawing on a 442 about 118- 119 amps. I spike at about 90A per side. That being said, you may be able to sneak by w/ the 120s. Although the 2200s will pull somewhere in the 125 range single drive, on a twin Id estimate about 100A per side. Not saying its a perfect set up, and your not going to be spinning 447s... but it could work. And it will all fit... barely. These hulls fill up really fast. There is no room at all for what we all want to do w/ them. Also, your rgiht on track w/ that set up... Id bet youll be darn close to 60. May not get you the reliablity you want though.. but if you keep an eye on things and dont do anythign drastic, people have pushed these 120s a lot harderFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Here's some photos of height. The EKOS is about 4mm taller due to a shorter cowl landing in the hull.Attached FilesFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Man... cut that lip and push it in there. There is no "No Dice".. only "how the He77 am I going to do this...."Attached FilesComment
So you figure I can push close to 60's with the 442 and 120's?
Twin Hydra 240's would require a LOT of battery. Might be too much for just two lipo packs.How does the ESC require more battery. Please explain.
Yeah, no doubt, set up right, you will be very close on 4S.Comment
