I do think since this hull is narrow it would be more stable as a twin!
Project Genesis!
Thank you for reply.
I have 3S batteries for my HOTR cat (4 sets), I can use them with the Genesis: 6S 5000mAh for two motors, but I think that run times will be shortComment
Just an update, today's first runs with SBEC on 4s, 447 ran 42.5 MPH
Run time was about 8 minutes, but I brought it in to check temps. Nothing too hot to touch. Wires were a bit hot though.
Using 5mm bullets and 10 gauge wire.
Next step, m445 and 6sFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Update:
Couple runs in this AM. Nice calm freshwater pond.
2 x 4s 5k 40c packs, 8 min runtime (15.2v left in pack after run- I pulled it in to check temps)
m445, 43.6 mph, nice smooth and straight. Dropped the strut down and she straightened up.
Temps all under 100F
I forgot the new 6s packs, so will have to give them a try the next time out. Might even drop the prop size to a 440 to help assure low temps and a good starting point for 6s.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Does anyone have the programming guide to the stock Genesis ESC? The download on Hobbyking comes up blank...............??? Anyone know what brand it is.............??NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Attached FilesFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Yeah, same file. I know I had to do some servo reversing to get the throttle to calibrate. I don't recall all the issue, but remember I did have some problem and ended up using 70/30 trigger with the throttle trim all the way to one side.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Hello
here are some new pictures of my genesis.
Drives and Ruder is mounted.Inside one Motor is mounted and the Lipoholders.
bye
mudlComment
Do you know how to get out of setup mode?
Thanks a bunch, just trying to use a cheap piece of equipment i got for little $.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
