I am having a hard time trying to get this to work right. I didn't realize when I first turned it on I had to calbrate the throttle so it's all messed up. It won't let me recalibrateit. Is there a reset button or something special I have to do to recalibrateit?and exactly how do iget to the program mode so I can do my lvc and what not? I read the instructions but doesn't say how to get to the program mode. Help would be greatly appeciated. I order the USB programmer but it's Gunna be a few days tillit gets here.
Programming aquastar 120 a esc??
Turn it on w/ full throttle applied... also, tap reverse to move to each section (I had to do that on one of mine but not the other?) Also be sure if your using Futaba you set teh throttle to reverse operation.Comment
Are you using a 3S batt? Just curious if thats why your getting 3 beeps. Not sure about the USB link as Ive never used one.Comment
Before you put that thing in water, check the water taps. They are loose from the factory and will leak and it'll fry on your first run.
... ask me how I know.
I recommend some threadlock too.
FYI- I had to reverse the throttle and hold it all the way forward to get it to calibrate. It seems to only like the 70/30 neutral setup as well.
________
BUY VAPOR GENIELast edited by FighterCat57; 02-14-2011, 10:50 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
1=full brake trim
2=default settings for the throtlle range....use the usb
3=starting again as the manual says.H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
BANDIT S"love boat" LEHNER POWERED..
RCFASTBOATS.GR MINI COOPER CATComment
