Turnigy vs aquastar
  • boater76
    • 505
    Turnigy vs aquastar
    Ok I'm looking for an esc for my cat. Don't know what to get either a Turnigy or Aquastar. What would you reccomend on experience with either?
    Ken
  • steveo
    • 1454
    seakings are good and i think they are the same as the turnigy
    • Make-a-Wake
      FE Rules!
      • 5557
      They are very similar, both by Turnigy..............the Turnigy Marine's have 2 capacitors.....the aquastar 4...........the Turnigy Marine however has a higher burst rate of 240a on the 120a's and the aquastar only 150............ On my HK login the price is $59 on the 120a Aquastar and $49 on the Marine..........I use The Marine's personally.
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        Aquastar! Much beefier and made by HiFei.
        • Diesel6401
          Memento Vivere
          • 4204
          I use a aquastar 120 in my ul-1 on a 7xl and so far I like it alot. I plan on stacking up on these especially since I have the programing box.
          - Diesel's Youtube
          - Diesel's Fleet
          • ozzie-crawl
            • Sep 2008
            • 2865
            on the HK site it shows the turnigy has better timing options with actual numbers shown
            but the aquastar only gives low,middle,high,auto. is this rite or does it tell you the timing numbers ?
            • CornelP
              • May 2009
              • 745
              Not with the software.... and actually the same through the Tx. Another minus is the lvc: only 3.0V
              • Diesel6401
                Memento Vivere
                • 4204
                I changed it, it's so easy to do everything with the program box. The timing is just Auto low middle and high. I just set it too auto and the lvc can be changed to Low Voltage cutoff (Default 6V, 5.0/6.0/7.2/8.4/9.0/12.0/15.0/18.0V)
                - Diesel's Youtube
                - Diesel's Fleet
                • CornelP
                  • May 2009
                  • 745
                  Correct, this means you can only set it to 3.0V/cell, next step being 3.6V/cell (for 2S, at least). That's ok compared to others, but I would expect to see something like the old models where you can select 3.0, 3.2, 3.4 etc. Timing is the same: low means 0-15dgr, middle 5-20dgr, high 15-30dgr.
                  • boater76
                    • 505
                    Which program box did you use Diesel?
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      My aquastar took a crap on me today. Magic smoke after a wicked crash in my ul-1.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • boater76
                        • 505
                        Did the crash cause the failure of the esc?
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          Yea, tube filled with water and fried the esc.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            What do you use to program the marine?
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              Are the swordfish and aquastars the same esc? Ratings size even the program box looks the same and both made by HiFei.
                              - Diesel's Youtube
                              - Diesel's Fleet
