2nd Genaration Skunkworks Kitty
  • bea5017
    • Aug 2009
    • 173
    Diego, That's what I have commin in!
    • egneg
      • 4670
      Originally posted by Diegoboy
      They look like the 4mm version of this
      No bushing - does the stuffing tube run through it, if so how do you adjust it?
      IMPBA 20481S D-12
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        Yep those are the ones. They supposed to be 3/16 stingers but they are well off. The hole was also different sizes throughout. I just drilled them out to 1/4" and made some bushings to fit the 3/16" shaft. I made my own bushings. I added links to post #11. In my opinion they are too short.
        • BakedMopar
          No Mo Slipah
          • Sep 2009
          • 1679
          Well I took her on it's maiden voyage. Got some footage. Will post it up later.
          • bigpapa
            • Apr 2009
            • 2330
            great lookin boat the color is awsome......................... cannot wait to see video
            • BakedMopar
              No Mo Slipah
              • Sep 2009
              • 1679
              Well here it is. Had to use half the pond as they were a fisherman at the other end. Was running a tad wet to me. It also had a bounce when you lift off the throttle. Looks as if the nose dives hard when you chop the throttle. CG was 28% from rear of sponson. Water was choppy with alot of current.
              • fqdawld
                • 109
                the color came out nice. call me up if you run tomorrow i gotta see it up close let me know if you still need the rx
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  #23
                  Originally posted by BakedMopar
                  It also had a bounce when you lift off the throttle. Looks as if the nose dives hard when you chop the throttle.]
                  that bounce is common,if you drop the throttle straight off the prop(s) drag causing the boat to bounce,just slow the throttle gently
                  some esc,s have a built in drag brake,if you drop the throttle it applies a automatic brake
                  which can make matters worse and can throw the boat completely out of the water
                  having not owned a cc i don't know if they have that feature
                  • bigpapa
                    • Apr 2009
                    • 2330
                    #24
                    sweet sweet boat my friend congrats on a job well done...............
                    • Norman2
                      • Sep 2008
                      • 321
                      #25
                      Hi, All I can say is WOW. Beautiful boat, color and installation. Now all you need is some cool
                      graphics. Enjoy it.
                      Norman2
                      34" Ekos Cat UL-1 Powered
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1679
                        #26
                        Thanks nice to know before I make unneeded changes. Brakes are set to off.
                        • Csaari77
                          • 21
                          #27
                          The boat looks good. Seeing this has lit the fire to finish my single version! Actually started painting yesterday.
                          • tiqueman
                            • Jul 2009
                            • 5669
                            #28
                            Baked, what speeds are you getting w/ the 8XL on 4S? I ran a 66.7mph this am (twin HOTR, 99.9% same hull on the bottom) w/ 10XLs on 6S, Amperage spikes at 180A. Thinking about running 8 or 9XLs on 4 and 5S to change up battery configurations. But Im darn happy where its at now!
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1679
                              #29
                              No idea how fast maybe 50? I like 4s. It's cheaper on the wallet. Your hauls on 6s.
                              • tiqueman
                                • Jul 2009
                                • 5669
                                #30
                                Are you running a 4S pack per side?
