Im setting it up per a discussion w/ Mudl from the forum. 2-3S packs in series, then parallelled to each esc.
HOTR twin build
that boat is going to be insane, i had mine in the 60s with 1 540xl on 4s
be interesting to see if it stays on the waterComment
Ozzie, what XL? Did you ever finish your twin build? I saw it on another forum last night.
Thanks Jerome!Comment
Stuffing tube ?
I tacked a motor mount in, trying to get the best fit for the motor. Is this too much bend for the stuffing tube?Comment
I could angle it a couple more degrees. It will put the front end of the motor almost against the lip in the deck for the hatch though. The HOTR lip comes so far down! It is easy to spin.Comment
There are two bends in your stuffing tube, shoot for one, it will remove much of the cable drag. Also try switching out the teflon tube and run 1 size up on the cable. I removed all of the teflon from my .130 cables and now run .150 in the same tube. Just add grease and watch for the increase in rpm.
Good luck with it! I assume that this is the same hull that was marked H & M?
John"When too much is just right!"Comment
Johnny, yes, same hull. Its come a loooong way.
I broke the motor mount loose and angled it as much I could and re-tacked it. And my goodness.. I barely put any epoxy on it the first time and man it bit. Twas a bear to get out. Yeah, I didnt like the "S" bend it was beginning to make. Thats why I shot the ? out there to OSE land. It may still have a very small one, put I dont think near as much as it did.
Pics coming soonComment
oops, missed that ? The mounts that came in it were close.. but not quite. They were off the angled part of the bottom, that goes to the side. So the mount went from the flat part of the bottom of the sponson and then angled up and hit the side about 1/8 or 3/16 above where the bottom meets the side. And the mounts stopped at the hatch lip. I took a piece of balsa, traced the existing mount, then looked at the mount in the boat and drew on the balse where I thought it should be.. bunch of trial and error and I made a CF template. then made the mounts off that.Comment
Dont know why I just didnt do it like that the first time...
Much better and now only one bend in the tube.Comment
Here are my stuffing tubes out of the Twin Simrad Maritimo.
She spins the props at about 37k.
These little suckers get hot and the thick grease turns to fluid very quickly.
The less curve on your stuffing tubes the better for less friction.
Better to angle the motor high to get the soft curve.
Nice build buy the way.
Going to be very fast.
BonewarSIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.Comment
