Nah Dave, your fine keepin it going here.
Well, Id say dont push it, but Im going to be running my ESCs at their max S count. The motor would be in the low to mid 30,000 rpm range. What Amp escs? If your Amp draw isnt too much, try it and see what happens. Check temps often though.
BUT, Id stick w/ 3S until you get it going right. Get yourself a base to start from, then start experementing. Least thats how I would go about it.
Do you have standard rotation props that match, that would be around the diameter of the EKOS props? If so, put them on and let it run just to see if it goes. It may not handle the best or try and walk a little, but it will give you an answer.
