16th. scale Finlay Atlas Van Lines
  • Xfactor
    Banned
    • 861
    #106
    u pay the s&h and 45 dollars u can get it. Just let me know.So you know I replaced those doo doo bearings out of the gate.The motor is straight just let me know.Im trying to get my paper together to play with my bigger stuff. I need 10s lipo at least 40c and i need 1 more big motor; 2 really.
    • Xfactor
      Banned
      • 861
      #107
      I love to trade.
      • Xfactor
        Banned
        • 861
        #108
        Maybe youll trade me one of your speed controls for something?
        • bigpapa
          • Apr 2009
          • 2330
          #109
          yup gotta wheel and deal 4 sure
          • Xfactor
            Banned
            • 861
            #110
            So far I managed to get the rudder/servo,reciever,and speed control, installed. I also glued the rear hatch in place.I still have a few more things to do like: Make the wings,the mounts for the wings,and install a turnfin.After I make the mounts for the wings it will be time to seal , glass it all in then prime.
            • Xfactor
              Banned
              • 861
              #111
              Is there any other way to post video other that you tube?Heres the driveline/motor test i just did. The forcemax esc is really smooth i got to disable the soft start though.http://www.youtube.com/watch?v=AWQYQ13GFbg
              • JimClark
                • 5907
                #112
                run it it will be totally different in the water under load. As long as the shaft is lined up well and free spinning just run it.
                Jim
                Billy Graham
                • Xfactor
                  Banned
                  • 861
                  #113
                  I guess you right the water itself kills the harmonics. The drive line is exceptionally smooth though . When I did it I chucked the coupler with a 1/8 rod with sandpaper glued to it to bore the stuffing tube hole through the floor; this assured alignment between the stuffing tube and the motor coupler. If you notice I have a lube boss on the stufing tube. I greased that wire then reinstalled it.
                  • Xfactor
                    Banned
                    • 861
                    #114
                    Hey Jim this is for you Check these two out.
                    • Xfactor
                      Banned
                      • 861
                      #115
                      Ill sell you 4 for 25 bucks.
                      • JimClark
                        • 5907
                        #116
                        I appreciate the offer but I most likely am going to get one of these and shorten the blade as it is a little long. I never thought it wouldn't be strong enough brass and silver solder are great
                        Jim
                        Billy Graham
                        • Xfactor
                          Banned
                          • 861
                          #117
                          Was gonna show yall the wings done but I cant post a pic all of a sudden
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            #118
                            Xfactor you said something about some other place to post vid try Vimeo, free if you dont do HD, but you will still get one free HD upload a week or month,,,PS got my Vegas hull finished and took it and my Miss Elam out today Vegas did 29,8mph and Elam did 41mph on GPS.. got some more tuning to do...
                            • Xfactor
                              Banned
                              • 861
                              #119
                              I like the scheme thats in the vegas hull. Whats its set up?
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                #120
                                The setup is a used blackjack motor and esc, motors 1500kv and esc is 45amp. I had to install new bearings in the motor and clean out the rust buildup when i got it,, the batts i used were two 6cell 7.2 4600 nimhs,, lipos would have been better,, may endup putting my like new UL-1 motor in it, it is 2030kv,, not sure yet...my pro boat Miss Elam has the same motor and esc as my Vegas hull and she ran 41mph on two 2s 7.4 5000lipos and the same 442 prop,,huumm
