O.K., water tested in the tub last night and there is a water coming in from under one of my battery trays that I epoxied in only hours before.
Soo, I had to dremel out the epoxy and remove the trays today in order to acess the leak. Turns out there was a teenie hole in the sponson from one of the areas where I removed the factory stringers. So I used some plastic epoxy to patch up the hole from the inside. Since the trays are already out, I guess nows the time to remove the rest of the wood stringers that were stopping me from moving the battery trays further back where they should be. I'll have to cut about 3/4 of an inch from the ends of the trays to remove the old epoxy and rough areas where I dremeled them loose. I'm gonna bathtub test it again tonight before re-epoxying the trays back in place. The other problem I am having is getting the stuffing tube to bend upward in order to set the strut higher. I tried to carefully bend the tube up, and I got it to bend just a little,but not enough. I pushed it upwards until it touched the bottom of the hull but it still springs back down. I'm afraid if I push it too much its gonna crack the hull. Anyone got any ideas??
