Scotts E-thundercat build
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Originally posted by dddmx3
    isnt 18" too long
    and is the teflon line the white stuff inside the stuffing tube?
    Yes, 18" is too long. I cut about 6-inches off. The stock flex shaft,however was too short because i had to move the motor mount towards the front of the boat in order to line up the flex shaft/motor coupler. So I needed a longer shaft and also a longer piece of teflon tubing(the white stuff)
    • dddmx3
      • Mar 2010
      • 233
      ok thanks.
      lol im doing the same conversion too!
      cant wait for the parts to come
      im doing the same thing you're doing so what size teflon tubing do i need?
      After all is said and done, more is said than done.
      • forescott
        • 2686
        ok thanks.
        I'm still waiting for parts too. I'll be watching your thread!
        • dddmx3
          • Mar 2010
          • 233
          hahah ok(:
          lol im thinking ill hit about 50mph
          • forescott
            • 2686
            Thats my goal as well!
            • dddmx3
              • Mar 2010
              • 233
              so what size teflon tubing did u get?
              • forescott
                • 2686
                Tubing for 3/16" flex cable or .187 from OSE
                • dddmx3
                  • Mar 2010
                  • 233
                  #23
                  oh i thought it would be a different size but ok
                  thanks!
                  • dddmx3
                    • Mar 2010
                    • 233
                    #24
                    where did you get the actual teflon
                    • forescott
                      • 2686
                      #25
                      Offshore Electrics
                      • dddmx3
                        • Mar 2010
                        • 233
                        #26
                        hmm i cant find it
                        not the tube..
                        • forescott
                          • 2686
                          #27
                          click on "drive hardware" Then "flex cables" then go to the very bottom of the page.
                          • dddmx3
                            • Mar 2010
                            • 233
                            #28
                            ohh thanks.
                            • forescott
                              • 2686
                              #29
                              Finally received the rest of my parts from Hobbyking this week. Turnigy 180 and some EC-5 connectors. I made a revised servo tray to accomodate the esc and receiver. Covered it, and my plywood hull re-inforcement with a couple of coats of clear polyurethane for waterproofing. Also swapped out all of the deans connectors on my batteries for EC-5 connectors. Made a parallel adapter from ec-5 connectors, deans 12 ga. wet noodle wire, and castle 6.5mm bullets. I have my props set up in order. CF-40 first, then x642, then m445, then m545(thanks for the reccomendations Propperchopper) Gonna have some more time to work on it today and I will post some more pics later.
                              • forescott
                                • 2686
                                #30
                                Got most everything put together today. Shortened motor wires, installed waterproof servo and steering linkage, loctite on everything, motor/esc /radio all work properly. Just need a little more silicone tubing for cooling, and need to adjust my batteries for center of gravity. Just about ready for a test run and am a little nervous.
