The 4mm shaft Steve sells will serve this purpose. The shaft is very stiff (being stainless and all), and will work great as a surface drive hanging about 3" out the back. If the angle is kept very low and the center of the prop is level with the bottom of the hull, it will do just perfect.
This design is very similar to how European hulls are layed out.
The flex coupler will allow the shaft to be VERY low in the bottom of the hull. The villain likes a bit of a downward prop angle anyways. It's one less thing to adjust as well.
The shaft will certainly need to be supported inside the hull, in at least two places. The 1/16 ply 20psinow has could easily be fashioned into 1/8" thick shaft supports. With the transom doubler this will be very sturdy.
Jon
Jon
