just purchased...
  • Simon.O.
    • Oct 2007
    • 1521
    Todd (Brushless55) has it sorted. A 9XL on 5S that is the same as my Cat that is a similar size to the MM.
    That twin on 6S a side is insane.
    Very cool but deffo a SAW boat.
    • Jeff Wohlt
      • Jan 2008
      • 2716
      The MM hull is probably the best in its size to fit a dual setup. Lots of room for motors.
      Motors are cheap and the thrill factor of twins is pretty cool....and look and sound great.
      www.rcraceboat.com
      [email protected]
        • 9488
        What Cat are you running 5s 9XL in?
        I snapped my shaft the last time out running 5s
        • ls1fst98
          • 859
          thats why i wanted to do twins on this hull. the 380 size that i posted a link to before is enough to power the 32" cat. but im thinking im going to stick with a single 9 or 10xl on 4s to start then go up to 6s.
            • 9488
            If you wanted twins, 540s would be a better choice IMO
            • bustitup
              • Aug 2008
              • 3071
              smart move man.....if you wernt building on a budjet i would say go with the twins
              you will still have a blast with the single and get to finish the boat sooner
              • ls1fst98
                • 859
                yea definately. when i get my tax return ill go with the larger twin hull i posted earlier in another thread. make my zerodefect boat ive been dying to do. in the larger twin im not too concerned about top speeds. more in the 40-45mph range but something that looks good both on the water and on the wall.
                • ls1fst98
                  • 859
                  #23
                  alright so heres what im gonna be ordering int he next week or so.
                  a 10xl motor with OSE cooling jacket.
                  thinking of trying the 180A turnigy esc unless theres a better one close in price. (dont mind spending a lil more as i can transfer over to other things along the way)
                  this motor mount: http://www.offshoreelectrics.com/pro...509b14&cat=123
                  i really want this hardware in black: http://www.offshoreelectrics.com/pro...-80085&cat=123
                  and a couple of through hull water pickups so i have one water pickup for each item (esc, motor, and mount)
                  • Rumdog
                    • 6453
                    #24
                    You will be better off going with an offset rudder to harness the mean machine's true handling abilities
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      #25
                      they do look nice they inline hardware.
                      they have a few problems tho,because the rudder is behind the prop it can cause the boat to be very squirelly at speed (dart from side to side).
                      if you ever want to run faster later on or race a offset rudder/strut is the way to go
                      • ls1fst98
                        • 859
                        #26
                        gotcha, thanks for the input. will make that change.
                        • highndry
                          • Nov 2007
                          • 664
                          #27
                          Talk to OBrien..he makes them go fast on spec power
                          Boats don't win races, drivers do.
                          • ls1fst98
                            • 859
                            #28
                            so would the round bottom version of this be better:
                            http://www.offshoreelectrics.com/pro...d=ros-21-strut
                            and then this rudder:
                            http://www.offshoreelectrics.com/pro...=ros-21-rudder
                            • ozzie-crawl
                              • Sep 2008
                              • 2865
                              #29
                              yes they will work great,same as what i run on my MM
                              • ls1fst98
                                • 859
                                #30
                                excellent. so stay tuned for the pics as the hull arrives.
