just purchased...
  • ls1fst98
    • 859
    just purchased...
    an Aeromarine Mean Machine bare hull. I am up in the air as to whether i want to do twins in it or run a single motor. I have read quite a few threads on here about the MM hull. im a fan of it and i like the new style cowl that is offered by a member here.
    look forward to this build and any advice/input is greatly appreciated.
  • Ctonez
    • Jul 2007
    • 404
    I've seen the boat run well with P-Spec parts (SV motor/ESC), I'd think twins would be overkill and alot more $$ and headaches.
    Just my 2 cents though...
    • Steven Vaccaro
      • 8723
      Now you need a new hatch!
      • m4a1usr
        Fast Electric Addict
        • 2038
        Neu 1515/1Y would do very nicely in that hull.
        John
        Change is the one Constant
        • bustitup
          • Aug 2008
          • 3071
          John
          I had the castle neu motor in mine thats the same as the 1515/1y 2200kv and mine did 46mph very very stable and turned like it was on rails
          • bustitup
            • Aug 2008
            • 3071
            did you get it with hardware or do you need a rudder and strut?...I have a used set available if needed pm me
            • ls1fst98
              • 859
              yes i do...debating buying that nice one ive seen or trying my hand at making a dual canopy style like some of the older m class offshore powerboats like this one
              • ls1fst98
                • 859
                would these be any fun for a bit just to get the layout and then get better motors as my budget allows? just curious...really would like to run twins...seen it done with this hull and it was pretty quick.
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  that looks like a bargain,but i think there 380 sized motors,even tho they mite work well enough a decent single setup would be faster and more reliable.
                  the stinger/flex setup can be a real pain as it uses a sqaure flex inside the prop shaft,basicly you need to remove the motor to remove the flex shaft.
                  you would still need 2 esc,s and 2 batteries.
                  if you decide to go single a fiegao 8xl on 4s can be a good budget setup and still get you in the mid 40s,then later on its just a case of upgrading one motor
                  just my 2c,your boat your build
                  • bustitup
                    • Aug 2008
                    • 3071
                    Only good thing about that kit is that it is convenient and cheap
                    The worst thing about it is that it has no longevity..........don't waist your time or money
                    Listen to ozzie
                    • ls1fst98
                      • 859
                      the more i look at it the more im definately leanin towards single on this hull...ill save my money and twin idea for a larger hull. i appreciate any advice especialy since im new the the brushless lipo setups. i have had my SV27 for about 2 yrs and i love that thing but never ran lipos til this christmas when i got the turnigy 2s 5000mah 20-30c packs and a charger.
                      will the 8xl be able to run on 2 3s packs as well as the 2s? id like to run what i have but also b able to run 6s in it at some point.
                      what size esc is recomended for the 8xl?
                      • bustitup
                        • Aug 2008
                        • 3071
                        the two 2s lipos will be perfect for the 8xl but i wouldnt run 6s on it for very long....maybe a couple minutes fur a speed run
                        depending on your budget for esc i would get a 120 or 180 turnigy 0r steve has some good cheaper esc's coming...ask him when they will arive
                        if u dont have the 8xl yet u might consider a 9 or 10xl so you can run 6s in future
                        gl
                        • ls1fst98
                          • 859
                          yeah i dont have the motor as of yet. only thing i do have is my sv27 stuff but id prefer to keep that boat together in case my buddys want to run with me. ill get a 10xl so i can go faster as i see fit. run the 2s for a while, grab a few 3s packs. I did like the turnigy esc's. so far ive read some decent reviews on them. what size prop would you guys recomend to start off with?
                            • 9488
                            I have a 9XL in my MM and it works great!
                            4s it does very well and love it on 5s..
                              • 9488
                              I agree, a decent single motor vs twin for this hull....
                              BUT I still love this video!
                              twin 9XL running 6s per motor
