Vision FE Tunnel Build
  • bonewar
    • Jan 2008
    • 549
    #61
    Cat-Boi
    This is a great thread.
    The quality of work is impressive.
    I am enjoying your work, makes me want to build 1.
    Thanks for sharing the build with us.
    Can't wait to see the finished boat.
    Cheers BONEWAR
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • Cat-Boi
      • 240
      #62
      Thanks for that Bonewar!
      I am past the toughest part and that to me is getting these cables right and tight. Remember you have to stretch them to length before cutting. These cables are very tight, zero slop and right on center. I used a dab of aeropoxy on the cables where they crossed in the wheel as per the vs-1 instructions and locktited the screws.
      Looking at the front, the seals are in place to hold the inner sleeve, this way the inners can be replaced easily and quickly if they wear out. Looking at the rear, bellows will seal off the cables nicely.
      Now it just down final radio layout , fixing the CG and battery location and final cooling tube and cable sealing (bellows). I think I will run her first before paint.
      I heard a 440 prop is a nice start point, any suggestions?
      Sandy Squitieri
      www.graupner-usa.com
      • Cat-Boi
        • 240
        #63
        30. adapter installed.
        31. This is at a full height on the motor/transom setting. Low profile is really paying off!
        Sandy Squitieri
        • sailr
          • Nov 2007
          • 6927
          #64
          How do we contact Kris Flynn for the adapters?
          Mini Cat Racing USA
          www.minicatracingusa.com
          • Cat-Boi
            • 240
            #65
            I usually PM him.
            Sandy Squitieri
            • Cat-Boi
              • 240
              #66
              In conclusion.
              Ok,
              the final layout sans the receiver for now. Just have to install the bellows in the rear ,cooling lines and tie down the esc, batt, etc.. and she should be ready to test. I did open up the stock water pick up to a more standard size.
              Thanks for tuning in , I think a nice different paint job is in the works.
              Sandy Squitieri
              • Kris Flynn
                #2 Bench Racer
                • 229
                #67
                Just to let people know, I am out of adaptors for now, I will be making some more soon.
                Excellent work Sandy! I just ran my 2 P-Spec setups on the weekend (my own design tunnel and an original Villain S1, and they are AWSOME!
                An M440 works well, but I still have to test more props and do some fine tuning.
                Kris
                • sailr
                  • Nov 2007
                  • 6927
                  #68
                  Kris,
                  How much are your adapters? Do you have them for the K&B and O.S. lower units?
                  Sandy, lookin great!!
                  Jim
                  Kris
                  Mini Cat Racing USA
                  • Cat-Boi
                    • 240
                    #69
                    Thanks Guys, what the hec... look ma! no paint!
                    just ordered the last bits from steve, should have her at the lake this weekend for a maiden run.
                    Sandy Squitieri
                    • sailr
                      • Nov 2007
                      • 6927
                      #70
                      I like it! No bling, all business!
                      Mini Cat Racing USA
                      • Kris Flynn
                        #2 Bench Racer
                        • 229
                        #71
                        I would start with the bottom of the bullet level with the sponson bottoms. But you will most likely be able to go as far up as 3-4mm under the bullet!
                        Kris
                        • Kris Flynn
                          #2 Bench Racer
                          • 229
                          #72
                          BTW this is a build thread, so I don't mean to do this, but to answer the question about price:
                          $35 for the adaptor
                          $15 for Coupler and
                          $5 for Shaft(normally $6.80)
                          Don't have any in stock, Sandy and Ray bought them all LOL j/k
                          Will post in correct aread of forum when ready.
                          Cheers
                          Kris
                          • Cat-Boi
                            • 240
                            #73
                            The final hook ups.
                            now we just need a lake without a fish kill!!!
                            Sandy Squitieri
                            • Kris Flynn
                              #2 Bench Racer
                              • 229
                              #74
                              I hope you have a 42X55 Prop in your collection, cause you are going to want to try it out
                              Even the 40X53 gets it going!
                              Oh yeah, while you are waiting you should sharpen the skeg at least
                              Kris
                              • Cat-Boi
                                • 240
                                #75
                                Thanks Kris! shes is just about ready to run, just gotta program the transmitter...
                                Sandy Squitieri
