BBY's 1/8 Pro Boat build
  • skellyo
    • Feb 2010
    • 592
    #121
    Originally posted by 6S HYDRO
    in order to do that you would have to have 10c 5,000 lipos- for 20c 10,00 2p
    2 10c pack in parallel = 20c
    40c packs in parallel would make 80 c , do you get it?
    That's incorrect. C rating does not change based on cell configuration. Capacity is what changes when paralleling cells.
    2 X 20C 5000mAh packs (100A) in parallel = 1 X 20C 10000mAh pack (200A)
    • 6S HYDRO
      • 1320
      #122
      10,000 mah 40c
      • 6S HYDRO
        • 1320
        #123
        when you parallel cells it doubles the mah capacity and the c rating
        • skellyo
          • Feb 2010
          • 592
          #124
          No it doesn't. Capacity doubles, C rating is a constant, always. If you put down the math behind what you're saying, you believe that the continuous current capability of a pack quadruples when you put two packs in parallel....that's not correct.
          Based on what you're saying:
          Incorrect method...
          20C 5000mAh pack = 100A continuous current capability
          2 X 20C 5000mAh packs in parallel = 40C 10000mAh = 400A
          Correct method...
          2 X 20C 5000mAh packs in parallel = 20C 10000mAh = 200A
          You see the basis behind all of this is that the C in C rating is the capacity. The multiplier ahead of the C in C rating is a constant, always. Double the capacity, the continuous current capability doubles, triple capacity and the continuous current capability triples and so on.
          • 6S HYDRO
            • 1320
            #125
            the amps doubled
            • skellyo
              • Feb 2010
              • 592
              #126
              the amps doubled- the c rate doubled
              No, the capacity doubled, not the C rating of the cells. A 20C cell is always a 20C cell no matter what kind of pack configuration you put it in. That single cell can only handle a specific amount of continuous current draw and that value never changes.
              • 6S HYDRO
                • 1320
                #127
                im not goin any further on this, its off topic for Randy's thread
                  • 9488
                  #128
                  Originally posted by rchippie
                  I was wanting to use 20c lipo's instead 40c lipos, to save some cash . But still have 10,000 . So what would that be using 4 5,000 20c packs ?.
                  just my opinion, if you want to save some cash maybe a different boat?
                  this is a big amp motor that should be backed by some good packs that can deliver the amps..
                  I would split the difference and go 30c packs.
                  • rchippie
                    • Jan 2010
                    • 567
                    #129
                    If it really needs the better packs then i will buy them . I was just checking if the other one's would be enough .
                      • 9488
                      #130
                      better to have more that just enough for high amp motors..
                      your batteries will thank you for that
                      • Jeepers
                        • May 2007
                        • 1973
                        #131
                        any motor can be a high amp motor, I saw a UL1 motor take out a Hydra 240.
                        • Rumdog
                          • 6453
                          #132
                          That littlescreamers outrunner should have fairly low amp draw being that it's only 650kv I believe.
                          • Jeepers
                            • May 2007
                            • 1973
                            #133
                            wrong skellyo is correct. the c rating stays the same.
                            here read carefully. I can search more to show you if you want
                            • Jeepers
                              • May 2007
                              • 1973
                              #134
                              also depends on how its propped, how wet the hull is running etc.
                                • 9488
                                #135
                                these motors can pull alot of amps
                                on their site they have ratings of 88watts to 160watts +, depending on application
