BBY's 1/8 Pro Boat build
  • rchippie
    • Jan 2010
    • 567
    #91
    Originally posted by RandyatBBY
    I am using 10S2P the cells are PollyRC 5S1P 5000mah X4 prop is real small X455.
    What kind of runtime can you expect with that set up ?.
    • RandyatBBY
      • Sep 2007
      • 3915
      #92
      Not a lot of data at this point but after the run on the video I had 66% left in the packs.
      Randy
      BBY Racing
      • rchippie
        • Jan 2010
        • 567
        #93
        10s2p so is that a total of 4 packs, two per side for a total of 10,000 mah ?.
        • 6S HYDRO
          • 1320
          #94
          that would be 4
          • 6S HYDRO
            • 1320
            #95
            yes 10,000 mah
            • rchippie
              • Jan 2010
              • 567
              #96
              Hi RANDY
              I just bought this hull & would like to convert it . http://cgi.ebay.com/1-8-scale-Miss-E...item335a10885a . I like the setup you did on yours & would like to do the same . I was thinking i would use the same motor you did . How much would it cost to make another mount like the one you made in your boat ?. Also how do i figure out were to place the mount in the boat ?. Thank's
              • RandyatBBY
                • Sep 2007
                • 3915
                #97
                Hi RANDY
                You can buy the parts from me and I will help you all the way. The ESC is from HobbyKing.com There is a bit to do but in the end it was worth it. Motor mount is $25.00
                Randy
                BBY Racing
                • rchippie
                  • Jan 2010
                  • 567
                  #98
                  I would like to use the stock proboat hardware if possible. So i dont have to drill any new holes in the hull. Unless there is better stuff that will bolt into the stock location, & is not super expensive . I will have to do this in stages do to finances . Do i call the shop to place a order ?.
                  • RandyatBBY
                    • Sep 2007
                    • 3915
                    #99
                    Check the bottom of the strut to the bottom of the hull this will determine whether you need new hardware or not. It needs to be 1.364 of a inch or 1 and 11/32ND of an inch. It will nor run right unless it is set at this height. I is all so necessary to have a 1/4 inch cable stepped down to 3/16. You can call me at 925 209 9572.
                    Randy
                    BBY Racing
                    • eboat
                      • Aug 2007
                      • 693
                      #100
                      Randy
                      When you say 66% left in the packs was that from the total of the 10 000
                      or was that 66% usable that was left
                      I know some of the pack checkers will say 0% when there is still the 20% left
                      • wolf IV
                        • May 2008
                        • 961
                        #101
                        hey Randy, mine sits right there .. Ididnt measure his but i think his is the same..?
                        http://www.youtube.com/watch?v=e-npTLBHefY
                        • RandyatBBY
                          • Sep 2007
                          • 3915
                          #102
                          Originally posted by eboat
                          Randy
                          I have found that having 25% to 30% left on my gauge is better for the cells, going below that damages the cells.
                          Randy
                          BBY Racing
                          • rchippie
                            • Jan 2010
                            • 567
                            #103
                            Randy what kind of runtime could i expect to get if i was only running 10s1p or 5,000 mah ?.
                            • K.R.Joye
                              • Feb 2010
                              • 1046
                              #104
                              Randy have you thrashed the Monster 2000 yet? Were all waiting!
                              ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
                              ****2008/9 MMEU LSO, 2008 LSH CHAMP****
                              ~~~~~~~70 MPH Club Member!~~~~~~~~~
                              • Doby
                                KANADA RULES!
                                • 7280
                                #105
                                Its not only run time you have to consider,,,running in a 1P configuration will stress the cells much more than a 2P configuration will.
                                Grand River Marine Modellers
