H&M Drifter 36" new lipo setup
  • Alfa Spirit
    • 2131
    The 36" Drifter is a very nice boat, I think that you don' t want a twin motor but that should be great.
    6S is good ant if you want a hot setup 8S is better with a 540 XL 14 turns motor
    • sampit
      • Jul 2009
      • 447
      Will I be ok to use etti 150A esc 6s2p 540 12XL Feigao 45mm prop
      FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
      Popeye Hydro T600 1400kv 6s1p
      • sampit
        • Jul 2009
        • 447
        anyone!
        • Fruity
          • Jan 2009
          • 147
          Sampit,
          I don't think the 12XL has enough kv to acheive what you are after on 6S, have a look at post #3 from 6ofthebest1, John has this set up very fast, I think you are better off with a larger diameter motor such as the neu, and you will need close to 2000kv to make it happen.
          Cheers...Tim
          • sampit
            • Jul 2009
            • 447
            If I was to use Neu Iv now been advised to use a 1415
            • Fruity
              • Jan 2009
              • 147
              Sampit,
              Both Fluid & John have the exact set up they are recommending, if you want to ensure success, you should take their advice...........
              Cheers...Tim.
              • Alfa Spirit
                • 2131
                Twin 540 12XL looks good to me or may be 580 sized L8 or L9 for more torque
                And high capacity batteries
                • tth
                  • Apr 2008
                  • 1510
                  • 6ofthebest1
                    • Jul 2009
                    • 41
                    you dont need big motors to go fast. just by running 2p you will gain speed
                    after doing some testing the etti esc dont rev as much as the castle esc i noticed 10 -15 kph slower with the etti so i would get the neu 1515 1.5y cc 240 6s2p x646
                    • bwells
                      • Jan 2009
                      • 842
                      How does 2p gain speed? I assume it was a typo
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        also how does the etti limit rpm?
                        • 6ofthebest1
                          • Jul 2009
                          • 41
                          #27
                          if you have used both etti and cc you will no where i am coming from
                          try running 2p in you boats see what happens
                          • ozzie-crawl
                            • Sep 2008
                            • 2865
                            #28
                            no i havent run either,just wondered how the etti limits the rpm?
                            since 30-40c batteries became readily available i no longer run 2p setups as my boats dont need anymore than that,and being 1p there lighter wich makes them faster. but everyones setup is diffrent
                            • richard templeman
                              • Feb 2010
                              • 9
                              #29
                              i have a 35in cat i whaht to see if you can halpe me i have a eitti 150 .i whant to run 6s .i do not know what motor and prop to get.
