NICE Solid or flex,prop under hull,what hardware ? Are there any plans yet? I will have to build one. Larry
1/6th Scale Crackerbox - Ruleset
A few more pics ready for hardware.Comment
What happened to the fiberglass hull somebody was making? Any news?Mini Cat Racing USA
Wel,I took the first step today,ordered the wood from National Balsa,about 50 mi from me. I will be modifying a Dumas SK into a C box, if I square up the sides it looks like a C box, almost flat on the bottom,L and W are good, wil add 2-3 in to length. The SK 2 is 27 in,want to end up with 29-30 in. WHAT do you think?? LarryAmerica home of the free, thanks to the brave [/url]Comment
Wel,I took the first step today,ordered the wood from National Balsa,about 50 mi from me. I will be modifying a Dumas SK into a C box, if I square up the sides it looks like a C box, almost flat on the bottom,L and W are good, wil add 2-3 in to length. The SK 2 is 27 in,want to end up with 29-30 in. WHAT do you think?? LarryThats funny, I thought about the same thing The SK is very close to a CB, I think your plan may work fine, Have fun with it. Thats the main idea. Keep us posted as to how it works out.
Finished
I spent most of Saturday finishing the Crackerbox, To get her redy for a test run, the first thing I did was to add the fotation, I used swimming pool noodle cut in to 6 inch sections and stuffed the cavities of the nose with it, Next I added bunks on the bulkheads near the floor in order to hold the batteries secure and increase COG adjustment, I also added a stand or shelf for the ESC. I waterproofed the bunks and shelf and moved on to the cooling pick up which I installed through the floor near the transome. Next I installed the Blackjack motor and strut. I sealed the adjustable strut where it enters the hull with some white caulk and let dry. Once dry I added the .130 drive cable, motor coupler and teflon tube then used shrink tube to help keep water out. I am using an SV-27 esc I had on hand which works well with the BJ motor and is smaller then the proboat esc. I then added a set of trim tabs I had built from aluminum angle and installed the rudder and steering servo assembly. Now the receiver and test, Everything went well and worked out for the bench test. I decided to add an antenna tube to the cockpit behind the mechanic that can be removed when not running but allows the receiver wire to be raised when in use. It looks like I'm ready for a test run today. Here are the photos of the lay ouy and hardware all ready to go.
Well the test did not happen, as mother nature did not cooperate.The pond that was open now has about a 10 foot ring of ice around it. It has been warm here during the day but pretty cold at night, Forercast is for warm days this week if the pond opens back up I'm ready.
