Hpr06
Uk SAW record holderComment
yes i do but id say 2cm max... its because ive heard of them breaking through the boxes at front... at least i know if i got running into another boat's side at 100mph ill come off betterHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
also any ideas on getting it 1:1 scale with the measurements i put on it?
this didn't workAttached FilesHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
You know the dimensions of the block, 24mm X25 mm
For the middle hole, on the horizontal, 5mm space, on the vertical 4.5mm
The big hole has 15mm diameter
The 4 small holes have a diameter of 2,5mm (3mm screw)
Vertically the distance of the extremity and the center of the small holes is 4,5mm
Horizontally the distance of the extremity and the center of the small holes is 3.9mm
You can do it the easy way, paper tape
And you draw the wholes with a pen or pencil, and then you take the tape of and apply it on the hull.Comment
And you draw the wholes with a pen or pencil, and then you take the tape of and apply it on the hull.might come up with annother version dunno
if it cant be read.. ill re boot in macAttached FilesHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
about to order my battery's, would PolyQuesr 5000 XQ 6S 22.2V 5000 (constant) 150.0A (burst) 300.0A be suitable was going to get hyperion g3's but too many mixed opinions.Hpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
I just recieved two Turnigy 6S 5000mah 40-50C batts from Hobby King. They sure look big. Hull is still at the painters so I am not sure how the fit is yet. I figured I would try the Turningy batteries and if they don't work so great, I will get higher quality batteries. I think I paid about 90 bucks a pop for them.Comment
Just ran the 4's 5000 mah 40-50c's this morning and they went out pre-heayed at 110 deg. And came in at 110 deg!!! They are amazing!!!!!!!! There is absolutely (no ) need to waste your money on name brand batteries when tunigy 's perform better than my poly quest set's!!Comment
it just doesnt seem right to have one of the best hulls with some of the best gear then Chinese lipo's i do have some Chinese lipo's for some of my lower powered set ups but will they last 50 runs at 100 amps maybe 150? i don't know what my motors are going to pull... the polyquest lipos are about $250 each so i could get 2 from china for the price
heh i will be saving 600 grams if i get the polyquest liposHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
Its up to you... I have over 3400.00 $ in lipos and started exsperamenting w/ the turnigy's.. Love them!!!!!!!!!!!!!!!! My set up is running at 200 amps consistant per side in the upper 60 's the entire run!Comment
