Ultra micro Inexpensive riggers
  • j.m.
    • Jul 2008
    • 838
    I have an idea.
    I want to make a pair of dinky little riggers for me and my close friend so we can race with each other.
    The tub/sponsons would probably be made out of the Dow 25psi XPS foam (blue insulation foam) covered with a layer of light glass.
    Basically like a Renegade, except even smaller. Think high speed pool racing.
    I am asking if this motor:
    Would be able to drive this prop:
    http://www.offshoreelectrics.com/pro...od=grp-2318.26
    On a ~500Mah 3s lipo
    Is a rigger with a length of around 10" with a straight shaft even feasible?
    ~Jon McLendon
  • crabstick
    • Jul 2008
    • 954
    There are some Depron rigger kits around
    heres a vid of one
    Matt.
    FE, Nitro and Gas racing in Auckland
    www.rcboats.co.nz
    • westbeach
      OSE Rocks!
      • 951
      heres a vid of one
      missing the link crabstick!
      HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
      • crabstick
        • Jul 2008
        • 954
        yeah doh, was on the phone, edited now
        Matt.
        www.rcboats.co.nz
        • westbeach
          OSE Rocks!
          • 951
          heres a vid of one
          http://www.youtube.com/watch?v=-BJ3Lfsw65g
          Thanks for fixing the link! Thats a cool little rigger. Will have to check one out for myself.
          • alvinsmith75
            • Jul 2008
            • 635
            That is the original renegade rigger.
            • j.m.
              • Jul 2008
              • 838
              Im not trying to argue that the renegade isn't good enough; it's a wonderful boat.
              I just like building things myself, and I believe I can do that for cheaper than purchasing a kit.
              I am also looking for something a bit smaller...
              I'm mainly just wondering about the power system, I have all the construction techniques down pat.
              I am also trying to have the boat as light as possible to allow for the smallest (and cheapest) power system components.
              • 6S HYDRO
                • 1320
                I would be down for one too.. And i have 2 rene's
                • Simon.O.
                  • Oct 2007
                  • 1521
                  John, I like the idea of a small rigger under 15"
                  The prop you pointed to looks fine, I have not yet used any outrunners but have done a lot of reading on the subject. It looks a little small at 14A.
                  I would like to know what is considered the bare minimum or too small for a renegade and go from there.
                  I am sure you have seen the threads on RCG about 12" rigger and 6-8" micros
                  I'll follow this one too.
                  • j.m.
                    • Jul 2008
                    • 838
                    That motor is just a tad smaller than the motors used for the renegades, and it can benefit greatly from a rewind. Being a cheap chinese motor, the winging isn't all that... perfect.
                    The props do look nice though.
                    I'd rather use a prop that my be a bit large compared to the scale of the boat that is from a reputable brand, rather than some mis-shapen off brand prop (look at all the little ones on tower hobbies, you'll see what I mean) that might fit the dimension requirements but severely lacks in efficiency...
                    I have all the materials needed to construct the hull. No problem.
                    Thing is, i'm a little short on money for electronics/ drive hardware. Need to go mow more lawns.. So don't expect any completed boats in the near future.
                    DRIVESHAFT IDEA>>
                    2mm piano wire (.078")
                    Prop end threaded with a metric 2mm tap to fit the graupner prop
                    1/8" K&S brass tube (stuffing tube) (2.46mm ID)
                    I will start making templates/ cutting foam this weekend for the tub & sponsons.
                    • j.m.
                      • Jul 2008
                      • 838
                      Possible gear:
                      http://www.hobbycity.com/hobbycity/s...r_(Blue_Series)
                      http://www.hobbycity.com/hobbycity/s....5mm_(3pcs/set)
                      http://www.offshoreelectrics.com/products.php?cat=38
                      (.25" stainless tubing; ID is .002" over 5mm)
                      • Ub Hauled
                        • Aug 2007
                        • 3031
                        Originally posted by Simon.O.
                        ...rigger and 6-8" micros
                        these are called NANO RIGGERS... seriously can you actually see them in the water?
                        8"!!!!
                        • Simon.O.
                          • Oct 2007
                          • 1521
                          8"!!!!
                          Decent size backyard pool ??
                          Beer, steak on the BBQ and rigger racing
                          • 6S HYDRO
                            • 1320
                            exactly- way cool
                            • j.m.
                              • Jul 2008
                              • 838
                              That's what I'm planning!! :D
                              But if they do actually turn out as fast as i'm hoping they'll be, I have quite a few ponds nearby and a lake to boot.
