I've finally managed to make some progress on the Bluebird & thought I'd start a build log on it here. I'm sure I'm going to need some help along the way so any hints, tips & answers to questions will be accepted gratefully.
stats-
Type... Well it's basically a rigger.
scale...1/8 = 36"long.
ply, foam, balsa & Glass construction.
Motor...580 9l
Batteries... 6s.
ESC... HiModel Gx 200A.
Prop... Starting with M445. (suggestions on this would be good.
In the pics you'll see the bits all cut & ready & then assembled. Foam will be added between the frames, carved to shape & then skinned with 0.6mm ply. Then a light glass over that. The sponsons are also foam with a 0.6mm ply skin. Nose tail & top blocks of balsa will be added & then a light glass. This will be fun.
Cheers.
Paul.
stats-
Motor...580 9l
Batteries... 6s.
Cheers.
Paul.
Seriously though, being limited to 4s at our club means I'll run it at North Lakes. It's a bigger piece of water & will allow it to run long & fast. Don't forget this baby wasn't designed to take corners.
Again I say "wish I still had it"
