"In series" won't work here, because the current to the two types of LEDs isn't the same (you'd end up with a white LED at less-than-half brightness).
Here's what you do: use my advice as above for the white LEDs, and run a separate chain for the red ones. Each chain will have its own resistor.
The supply voltage from the receiver should be the same as the battery you've got hooked up to it (If you're running a BEC/ESC, assume 6.0 volts).
