SP40 WHIP-KILLER project
  • K.R.Joye
    • Feb 2010
    • 1045
    Heres some pics of my winter project. Our MMEU club runs SPORT 40 (any hull per NAMBA SP40 rules Any Motor up to 6S lipo). I decided to scratch build a one-off 35" Sport Hydro based on a lo-pro Whip style design. The hull will be built similiar to a rigger with a composite tub & replaceable sponsons.
    SPECS:
    TUB~ 26"L x 10"W @ beam tapered back to 8" W transom. 1/8" Ply frames skinned with .046 G10 sheet, G10 Strut wetwell
    SPONSONS~ BBY SP40(Winston) Glass Molded w/G10 inside closeouts
    CANOPY~ ABS modified DUMAS tunnel
    POWER~ARC 36-75-1 1680kv, 6S1P 40C lipo, Huaya BX200 ESC
    HARDWARE~ 3/16 Flex/Stub, Speedmaster Strut (thru hull mtg)MACH 5 Cleaver rudder, HS645mg steering servo
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
  • K.R.Joye
    • Feb 2010
    • 1045
    More pics
    Heres some pics with the deck on, Canopy mockup, and sponson assembly. The sponsons are fastened with 1/4" SS bolts, sealed blindnuts bonded on the G-10 closeout panels.
    Modified DUMAS Tunnel Canopy will be mounted separately from the hatch(minus canopy / rigger classes).
    Next step will be cutting the hatch opening, and fitting, motor, hardware, coming soon.........
    • RandyatBBY
      • Sep 2007
      • 3915
      This is really thinking outside the box. Looks cool. If you want a FG cowl I make a hooters.
      Randy
      BBY Racing
      • K.R.Joye
        • Feb 2010
        • 1045
        Thanks Randy i'm all set, now that i got the sponsons assembled its smooth sailing.
        • mhall
          • May 2008
          • 44
          That's a great looking boat. Any chances of seeing any video of it running??
          • Steven Vaccaro
            • 8721
            Great job Ken. May I ask why the removable sponsons? Will they be adjustable?
            Steven Vaccaro
            • K.R.Joye
              • Feb 2010
              • 1045
              Thanks guys for the nice comments. I hope to get some vids of all my high speed stuff running this year. Just got a new mini cam.
              STEVE i wanted to make the sponsons replaceable just in case....Boats in this class really move. They are dialed in right now for a preset AOA. If i need to adjust them i have the option within a few degrees.
              • longballlumber
                • 3132
                Defiantly outside of the box Ken… Will this one get the outrunner treatment too?
                • K.R.Joye
                  • Feb 2010
                  • 1045
                  Hey Mike i have a special inrunner for this one. Will see how it works out.......
                  • Cat-Boi
                    • 240
                    now that is just plain cool!
                    Sandy Squitieri
                    www.graupner-usa.com
                    • andym
                      More Go Than Show Prop Co
                      • 2406
                      WOW, Ken nice work and a great thought process!!! What sort of weight are you aiming for?
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        very sweet indeed, but as usual i have a stupid question, how do you remove and adjust sponsons i see bolts on the side can you get to these threw the hatch opening ?
                        • K.R.Joye
                          • Feb 2010
                          • 1045
                          Thanks again for the nice comments, i'm shooting for a RTR of 9-10lbs(G10 is incredibly strong but heavy). Once i cut out the hatch opening(this weekend) theres plenty of access to the sponson attachments. The sponson bolt heads nest on the inside of the 5" tub stringers. Hatch opening scribe lines are on deck pic#5.
                          • K.R.Joye
                            • Feb 2010
                            • 1045
                            More SP40 WHIP Killer pics
                            Its been a while but i have progressed. The hull has been completely assembled and custom hardware installed. Heres the latest pics, next step it will be torn down for priming and finish paint.
                            • K.R.Joye
                              • Feb 2010
                              • 1045
                              More Whip Killer Hardware
                              Driveline has been offset 1/4" to counter act prop torque. Strut `Wet Well' is sealed off from the rest of the hull.
