Raptor Rigger Build
  • detox
    • Jun 2008
    • 2318
    Raptor Rigger Build
    Just started my Raptor Rigger build. I built a jig to hold everything strait and square. The basswood 3/32" x 1" ride pads were added to the first generation wooden sponsons. I purchased and cut a single 4 foot piece of 3/8" carbon tubing to make inside spread of sponsons wider @14"(1/16" toe in). Booms will be bolted to tub, but they will be adjustable for testing. First off sponsons will be set slightly wetter than Brians recomended setting.
  • Rumdog
    • 6453
    Awesome!! nice and wide, should be really stable. SAW's or oval?
    • detox
      • Jun 2008
      • 2318
      LSH oval. I hope it keeps up?
      • Fluid
        Fast and Furious
        • 8012
        LSH oval. I hope it keeps up.
        Hmmm, pretty narrow transom for an LSH......
        • detox
          • Jun 2008
          • 2318
          Excuse me ...my mind is still on my UL-1 Superior. I'm hoping to run the Raptor Rigger in P-Spec Hydro class.
          • raptor347
            • Jul 2007
            • 1089
            Lucky #13? Looking good.
            The original sponson setup is "safe", I wouldn't take any angle out.
            Brian "Snowman" Buaas
            Team Castle Creations
            NAMBA FE Chairman
            • detox
              • Jun 2008
              • 2318
              Lucky #13 it is. Thanks
              • Doug Smock
                Moderator
                • 5272
                Looking good Keith!!
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • teach
                  • Jun 2008
                  • 509
                  That fourth picture makes me drool.
                  • detox
                    • Jun 2008
                    • 2318
                    Originally posted by D.Smock
                    We have six on odrer.
                    Hoping to run a P-Spec Hydro class at our Grand Prix next year.
                    Doug
                    Thanks Doug!
                    • Darin Jordan
                      • 8335
                      That Baby is gonna be NIIIICCCEEEE!
                      These boats are just SEXY!!
                      Darin E. Jordan - Renton, WA
                      • detox
                        • Jun 2008
                        • 2318
                        Thanks Darin,
                        I plan on mounting my motor a little different than most. I will use OSE's aluminum mount epoxied to hull floor. That way any wiring or tubing can run along side of tub without mount interfering. I will purchase the "Flat" No bend version, so I can bend it how I want it.
                        http://www.offshoreelectrics.com/pro...od=ose-drmount
                        • Darin Jordan
                          • 8335
                          Originally posted by detox
                          Thanks Darin,
                          Only problem with this is that the motor mount adds rigidity to the center of the hull... I have the plate style, but I trimmed down the top and sides to wires go right over it.
                          • Jeepers
                            • May 2007
                            • 1973
                            why? do you have a thing for tomatoes?
                            Detox nice build!
                            • detox
                              • Jun 2008
                              • 2318
                              I know what you are saying, but I will add a piece of 6mm carbon fiber plate between the servo/reciever compartment and the motor /esc compartment. I think raptor347 has started doing this on his builds, but he uses plywood. Taping down the hatch also adds rigidity.
                              Look closely at picture.
