Results 1 to 25 of 25
Thread: P-Limited Mono Prop recommendations
    Jan 2008
    VA
    3,070
    Default P-Limited Mono Prop recommendations
    Hey folks, After getting out of the FE game five years ago, I decided to build a P-limited Cyberstorm with a 3630 1500 KV motor. We don't run P-Limited Mono in D12 so I need some oval heat racing prop recommendations. Of course I want something fast, but I'm also looking for reliability (don't want to push the equipment too hard) I'm running a 150 amp controller. Roughly how many mAh can I expect to burn in a 1 mile heat? Thanks!
    Jul 2007
    or
    1,088
    1915-17-45 ABC on the 1500kV should be fast and reliable.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    Jul 2007
    642
    5000-mah is enough for the 1 mile.
    I race this hull and have found cg balance is everything.
    Make your ideal marks and play with it in different water
    conditions. It is the fastest the more tail heavy you run,
    but also to more difficult to drive.
    You will need 6000-mah or more if you run offshore.
    TenShock Brushless / Pro Marine
    NEU Motors / Rico Racing/ Castle Creations
    2023 NAMBA & 2018 IMPBA FE High Points "National Champion"
    Jan 2008
    VA
    3,070
    Excellent info gentleman. Thanks a bunch! I set up the boat for 2P with the packs outboard so I would have more play room with the CG. Will probably get a pair of 4s 3300's for oval racing. I built the boat for Offshore at IMPBA Spring Nats in Atlanta (which was supposed to bet this weekend). She'll see oval time until I can make it down. Atlanta runs P-Lim on the big Open Offshore Course so I see a pair of 5,000's and a bunch of prop testing in the future. :)
    2,917
    Mike - Atlanta runs under IMPBA rules - NO limit on mAMPs, or # of packs parallel.
    Jan 2008
    VA
    3,070
    Thanks Larry. I was concerned with unnecessary weight from bigger batter packs. I know extra weight was no issue and many times beneficial with the P-Monos I had built in the past. I don't know if this is the same case with P-Limited. I built this new boat light.
    6,192
    A pair of 3300's is perfect but you will likely overheat the 150 on the 1915. Once it shuts down.........throw it away. They don't ever work right again.
    Noisy person
    Jan 2008
    VA
    3,070
    Interesting Terry. What do you suggest for a prop then??
    Jun 2011
    789
    As Terry indicated the pair pf 3300's are perfect. The extra ma's pay off in lap 5-6. For a 1500kv motor you need pitch but not diameter. Try a 1716-1717 or cut an M545 down a little. OR spend $50 on a leopard 3660 2050kv and just use the 1500 for offshore classes. 2050 and a 1714 is a great setup and or try a CNC 442/3.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    6,192
    Sorry Mike. I totally missed the 1500kv part of the equation. That 1915 will work without hurting any of the parts.
    Noisy person
    9,402
    Nice thread. I was going to try the 1915 on a 1500kv Dyna.
    Runs good in my DF33 with 10k on board.
    Looking forward to test running asap.
    Jan 2008
    VA
    3,070
    It's all good Terry. I remember about 8 years ago when it seemed the 445 was the go to prop for P-Lim Sport Hydro's on the West Coast. That prop however was just too much for my club pond. I tried it out and it ran hot. In the years following, we had two newbies also try the 445. One I believe even had a boat built by Tony. I warned them both not to run too long on the first run. They didn't listen and . It always pays to be cautious on the first run.
    Thanks to everyone for their input.
    I miss the OSE forum. Lots of good folks and good threads...unless the subject is P-Limited rules... LOL At this point I'm content being a sheep.. baa
    6,192
    Yeah, the M445 was perfect for the 2000kv Aquacraft motor but it was on the ragged edge of baked potato. Another nice prop for hydros on the AQ motor was the H5. Great setup. Also close to the edge. Trouble with being at the edge is it's easy to cross over to the dark smelly side. Put the batteries in the wrong spot in a mono and fr'shizzle.
    Then the glitch in the supply matrix happened and a bunch of guys that had their boats pretty sorted (they thought) started melting motors. Ugh. All ancient history now.
    Noisy person
    ca
    6,963
    Hi Mike !
    Haven't really had a P-Ltd Mono class out here in L.A. I agree the m445 in an FE30 works well with a motor from the good batch. For P'Ltd. Cat we went down to 1800 motors with a m445 or the AZ guys use 1500's with biggie props. BTW Don Huff has the Drifter now
    Jan 2008
    VA
    3,070
    Hi Tony, That Drifter gets around. LOL Don must have some record trials in mind.. We haven't had a record trials in my district for a couple years now. I kind of miss it.
    Dec 2014
    Ga
    544
    Me at a Record trials?????????????? Yes just waiting for the virus to go away so I can test it.
    Tony I did a full rebuild and stiffing up on the boat. I'll try to put some pictures up of it.
    Dec 2014
    Ga
    544
    I bet you thought that you would NEVER see that Logo again!
    6,192
    Is that an old Dennis Whitt boat?
    Noisy person
    2,917
    Steve Resser use to run one as well. (at one race in MI. he had two 1/2" wrenches taped to the deck)
    Dec 2014
    Ga
    544
    Terry, it's a Hydro&Marine drifter-S from Germany.
    https://forums.offshoreelectrics.com...older-for-Sale
    It's to little to heat race with, I think, And I don't want another boat to race with anyway. I bought it just to do time trials with.
    6,192
    I knew what it was. Dennis had a couple of these for trials. One held the P offshore record for a bit. I thought this might be one of them. These never turned worth a damn but going straight they were solid. There used to be a 36" version you might be interested in too.
    Noisy person
    Dec 2014
    Ga
    544
    NOPE not at all.
    The ONLY reason I have a blasted cat in the first place is to try to get the limited cat record. I like monos!
    ca
    6,963
    Quote Originally Posted by donhuff View Post
    NOPE not at all.
    Don,
    Check your E-Mail - I have a present for you
    ca
    6,963
    Brian had the NAMBA LSO record in 2005 at 33.25mph. My original Pachmeyer-built DrifterS bested that in 2006 with a scorching 34.10mph.
    Jay launching it :
    In 2007 Jim (Jevmax) added some mph with the winged version of the hull
    Don's boat (that he got from me that I got from Mike)is the one that now holds NAMBA P-Ltd Cat record - Twice the mph from 2006
    9,402
    I used to own one of Paul P.'s Drifter S. It was yellow and had Mountain Dew decal scheme and I sold that long time ago with octura inline strutter.
    Is it the same boat making these rounds?
