Results 1 to 3 of 3
Thread: Motor runs after transmitter is turned off
    Sep 2018
    Tx
    11
    Default Motor runs after transmitter is turned off
    I have just finished building a Genesis 900 with stock motor. I used a Seaking 180a V2 esc. Currently set up on 3s batteries. I used a Spectrum DX5C transmitter With a SR415 receiver..
    It set up relative easily for novices except for the fact that when you turn off the transmitter the boat motor starts running. If any one has any ideas I would appreciate it. I am not to tech savy
    so hopefully it is a simple remedy. Thanks
    Nov 2008
    Ql
    3,096
    A very easy remedy.
    It is normal practice to always turn off the power in the boat first & then the transmitter.
    Startup is the opposite.
    Always turn on the Transmitter first & then connect the power in the boat.
    Sep 2012
    Tg
    1,083
    As Paul has stated, plus set the throttle failsafe. I am not familiar with Spectrum stuff so check the manual. Then if you have a signal failure on the water your boat will stop instead of racing off and causing damage.
