An outsiders view here, take it or leave it.
It seems that you are trying to limit power by using the motor as a fuse, and are having issues with people pushing the motor too hard and blowing them, motors changing spec within production, and going out of production, but it looks like if you open the motor spec up
to allow decent non RTR motors, you will allow full on P power with it, which is likely to kill either the limited or the full P class.
Have you thought about limiting the power electronically, instead of with a very expensive fuse?
https://neumotors.cartloom.com/store...imiter-2017-18 From what I gather 1KW is a decent but fairly conservative power for P Ltd, that should not result in lots of blown RTR motors, even if you didn't get one from "the magic batch", you could open it up to any motor, and while expensive books will have a slight efficiency advantage, the difference will be a heck of a lot less than the difference between 2 people with the exact same motor, one of which runs conservatively as they need it to last for years, and one who poo uses the limits as they don't mind burning one now and again.
I haven't used the above device, I just saw it and thought of you guys, maybe it is the answer to your prayers, maybe due to the peaky nature of boat power vs the steady power of an aeroplane it can't work, or maybe New could do some mods and make it work.
In Naviga are just going away from using our batteries as fuses and are using electronic energy limiters instead, which is perfect for us as we have a set run time, but with the right energy limit set could work for you too, if boats are too peaky for a power limit to be feasible. There are 3 manufacturers of boat energy limiters, and they have 2 years of national level testing behind them, but are just being legalised internationally this year. China race to Naviga rules too, so I expect we will see an energy limiter come out of China at a lower price point than the European made ones before too long.
